Mon Oct 15, 2012 12:22 pm
Thanks, I see the following occurs in the log files when it hangs.
(initiator)
10/15 14:11:00.430 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:00.830 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:01.231 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:01.631 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:02.031 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:02.431 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:02.831 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:03.231 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:03.631 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:04.031 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:04.431 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:04.831 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:05.231 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:05.632 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:05.926 Found language dll: language id: 0x0409 (English (United States)).
10/15 14:11:06.032 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:06.432 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:06.832 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:07.232 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:07.632 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:08.032 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:08.432 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:08.832 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:09.232 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:09.632 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:10.032 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
10/15 14:11:10.432 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
and target device is
10/15 13:33:04.183 7d4 Params: <<< String param 'InitiatorName': received 'iqn.2008-08.com.starwindsoftware:server03.domain-autoloader:server02', accepted 'iqn.2008-08.com.starwindsoftware:c
dbhodpm03.domain-autoloader:server02'
10/15 13:33:04.183 7d4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:server03.domain-tapedevice', accepted 'iqn.2008-08.com.starwindsoftware:server03.domain
int-tapedevice'
10/15 13:33:04.183 7d4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
10/15 13:33:04.183 7d4 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
10/15 13:33:04.183 7d4 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_4-scsi#6&13fd438&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': share: 3 ('rw').
10/15 13:33:04.183 7d4 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_4-scsi#6&13fd438&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'HP Ultrium 4-SCSI W61W': adapter 5, bus 0, target 4,
LUN 0; maxTransferLength 16777215, alignmentMask 0x0
10/15 13:33:04.183 7d4 Tgt: open 'iqn.2008-08.com.starwindsoftware:server03.domain-tapedevice': 1 session(s) opened, 65535 more allowed.
10/15 13:33:04.183 7d4 Params: >>> AuthMethod=None.
10/15 13:33:04.183 7d4 Params: >>> TargetAlias=TapeDevice.
10/15 13:33:04.183 7d4 Params: >>> TargetPortalGroupTag=1.
10/15 13:33:04.183 69c T[2,1]: session 0x2, connection 0x2 : end of stage 0, next stage 1.
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
10/15 13:33:04.183 7d4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
10/15 13:33:04.183 7d4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'DefaultTime2Wait': received 5, accepted 5
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'DefaultTime2Retain': received 20, accepted 20
10/15 13:33:04.183 7d4 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
10/15 13:33:04.183 7d4 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
10/15 13:33:04.183 7d4 Params: >>> ErrorRecoveryLevel=0.
10/15 13:33:04.183 7d4 Params: >>> MaxConnections=1.
10/15 13:33:04.183 7d4 Params: >>> HeaderDigest=None.
10/15 13:33:04.183 7d4 Params: >>> DataDigest=None.
10/15 13:33:04.183 7d4 Params: >>> OFMarker=No.
10/15 13:33:04.183 7d4 Params: >>> IFMarker=No.
10/15 13:33:04.183 7d4 Params: >>> InitialR2T=No.
10/15 13:33:04.183 7d4 Params: >>> ImmediateData=Yes.
10/15 13:33:04.183 7d4 Params: >>> MaxRecvDataSegmentLength=262144.
10/15 13:33:04.183 7d4 Params: >>> MaxBurstLength=262144.
10/15 13:33:04.183 7d4 Params: >>> FirstBurstLength=65536.
10/15 13:33:04.183 7d4 Params: >>> DefaultTime2Wait=5.
10/15 13:33:04.183 7d4 Params: >>> DefaultTime2Retain=20.
10/15 13:33:04.183 7d4 Params: >>> MaxOutstandingR2T=1.
10/15 13:33:04.183 7d4 Params: >>> DataPDUInOrder=Yes.
10/15 13:33:04.183 7d4 Params: >>> DataSequenceInOrder=Yes.
10/15 13:33:04.183 69c T[2,1]: session 0x2, connection 0x2 : end of stage 1, next stage 3.
10/15 13:33:04.183 69c C[2], IN_LOGIN: Event - LOGIN_ACCEPT.
10/15 13:33:04.183 69c C[2], LIN: T5.
10/15 13:33:10.906 498 conf: Accepted control connection from 127.0.0.1:52232.
