add second device on the same target
slglaks
Sun Sep 23, 2012 9:26 am
hi
i need to add second device (another Hard drive) to the same target.
i cannot find the way to add another device because it gives an error that the target is already defined.
can someone help me?
i am using ISCSI from the windows server and connected to the server that the starwind is installed on it.
Mon Sep 24, 2012 2:42 pm
Would you be so kind to specify what device type are you using (CDP, Deduplication, HA, etc)?
slglaks
Mon Sep 24, 2012 2:47 pm
hi
i am using the starwind to create folder to our backup server.
i am using it as Deduplication folder for the symantec backupexe 2013.
i want to create another Dedup folder to the system and i cant add another device to the same target(the backup server Iscsi)
hope is is clear now
Mon Sep 24, 2012 3:11 pm
You need to right-click on the target and in the dropbox menu that will appear (I have attached the corresponding screenshot) you need to choose add a New Device to the Target option.
slglaks
Mon Sep 24, 2012 3:26 pm
hi
i dont have this option!
i have only:
Add Target
Remove Target
Force Remove Target
Move to group
i have license for use StarWind Enterprise Mirroring & Replication Edition
a am using ver 5.7.1733
Mon Sep 24, 2012 4:15 pm
Well, then you need to update your SAN to the current version, which is 6.0
slglaks
Mon Sep 24, 2012 5:19 pm
hi
do i need to upgrade or i need re buy new licence?
Mon Sep 24, 2012 8:26 pm
Since you are running pretty outdated version version you will probably need a new key, which will come free if your ASM is valid.
I will ask sales representative to contact you regarding this.
slglaks
Mon Sep 24, 2012 9:20 pm
Hi
Thanks.
This is very importent.
I hope i will not need to buy new key.
Tue Sep 25, 2012 7:58 am
Dear sglaks,
Since you do have valid ASM I will answer you in PM on your mailbox (that will basically guarantee faster response time).
Thank you
