Trouble connecting to iSCSI target
jason.bashaw
Fri Sep 14, 2012 2:49 pm
Trying to connect to iSCSI target from Microsoft Systems Center Virtual Machine Manager and I keep getting this error: Could not retrieve a certificate from the 10.20.0.2 server because of the error: The underlying connection was closed: An unexpected error occurred on a send.
Specify a valid server name and port.
Details: An existing connection was forcibly closed by the remote host (0x80072746)
Server and port are both valid. I have instances of Xen Server that are attached to this target as well. Any help would be appreciated. Log from today below.
9/14 7:39:22.335 35a4 Srv: Removing target 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01' [FORCE]...
9/14 7:39:22.347 35a4 C[1], LIN: Event - SHUTDOWN.
9/14 7:39:22.347 35a4 C[1], LOGOUT_REQUESTED: T11.
9/14 7:39:22.347 35a4 C[2], LIN: Event - SHUTDOWN.
9/14 7:39:22.347 35a4 C[2], LOGOUT_REQUESTED: T11.
9/14 7:39:22.347 35a4 Tgt: iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01: device 'DDDisk1' is detached.
9/14 7:39:22.389 1ac C[1], LOGOUT_REQUESTED: Event - LOGOUT.
9/14 7:39:22.390 1ac C[1], IN_LOGOUT: T9/10.
9/14 7:39:22.390 108c C[1], IN_LOGOUT: Event - LOGOUT_ACCEPT.
9/14 7:39:22.390 108c C[1], FREE: T13.
9/14 7:39:22.390 4594 C[1], FREE: recvData returned 10054
9/14 7:39:22.389 1d80 C[2], LOGOUT_REQUESTED: Event - LOGOUT.
9/14 7:39:22.395 1d80 C[2], IN_LOGOUT: T9/10.
9/14 7:39:22.403 35a4 PR: Set Unit attention 0x3f/0xe for session 0x1 from iqn.1991-05.com.microsoft:symhyper-v-01.symcominc.office,400001370001.
9/14 7:39:22.404 35a4 PR: Set Unit attention 0x3f/0xe for session 0x2 from iqn.1991-05.com.microsoft:sym-000125.symcominc.office,400001370000.
9/14 7:39:22.404 35a4 Tgt: iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01: device 'ImageFile1' is detached.
9/14 7:39:22.417 2df4 C[2], IN_LOGOUT: Event - LOGOUT_ACCEPT.
9/14 7:39:22.418 2df4 C[2], FREE: T13.
9/14 7:39:22.420 2b00 C[2], FREE: recvData returned 10058
9/14 7:39:22.430 35a4 Srv: Target 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01' has been removed.
9/14 7:39:22.511 1ac error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
9/14 7:39:22.511 3d14 Srv: Accepted iSCSI connection from 192.168.1.169:55234 to 10.20.0.2:3260. (Id = 0x1f)
9/14 7:39:22.511 1ac Tgt: close 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01': 1 session(s) opened, 65535 more allowed.
9/14 7:39:22.511 3d14 C[1f], FREE: Event - CONNECTED.
9/14 7:39:22.511 3d14 C[1f], XPT_UP: T3.
9/14 7:39:22.512 3ba0 C[1f], XPT_UP: Login request: ISID 0x400001370001, TSIH 0x0000.
9/14 7:39:22.512 1d80 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
9/14 7:39:22.512 1d80 Tgt: close 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01': 0 session(s) opened, 65536 more allowed.
9/14 7:39:22.512 3ba0 C[1f], XPT_UP: Event - LOGIN.
9/14 7:39:22.512 3ba0 C[1f], IN_LOGIN: T4.
9/14 7:39:22.513 3ba0 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:symhyper-v-01.symcominc.office', accepted 'iqn.1991-05.com.microsoft:symhyper-v-01.symcominc.office'
9/14 7:39:22.513 3ba0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/14 7:39:22.513 3ba0 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01', accepted 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01'
9/14 7:39:22.513 3ba0 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
9/14 7:39:22.513 3ba0 T[1f,1]: Login request: target 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01' does not exists.
9/14 7:39:22.513 2490 C[1f], IN_LOGIN: Event - LOGIN_REJECT.
9/14 7:39:22.513 2490 C[1f], FREE: T7.
9/14 7:39:22.515 3d14 Srv: Accepted iSCSI connection from 10.20.0.2:39081 to 10.20.0.2:3260. (Id = 0x20)
9/14 7:39:22.515 3d14 C[20], FREE: Event - CONNECTED.
9/14 7:39:22.515 3d14 C[20], XPT_UP: T3.
9/14 7:39:22.516 2de8 C[20], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
9/14 7:39:22.516 2de8 C[20], XPT_UP: Event - LOGIN.
9/14 7:39:22.516 2de8 C[20], IN_LOGIN: T4.
9/14 7:39:22.516 2de8 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:sym-000125.symcominc.office', accepted 'iqn.1991-05.com.microsoft:sym-000125.symcominc.office'
9/14 7:39:22.516 2de8 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/14 7:39:22.516 2de8 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01', accepted 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01'
9/14 7:39:22.516 2de8 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
9/14 7:39:22.516 2de8 T[20,1]: Login request: target 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-xenvol01' does not exists.
9/14 7:39:22.516 32d4 C[20], IN_LOGIN: Event - LOGIN_REJECT.
9/14 7:39:22.516 32d4 C[20], FREE: T7.
9/14 7:39:32.574 3214 Srv: Remove Complete '\\?\SCSI#Disk&Ven_ROCKET&Prod_DEDUP_DISK#1&1c121344&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}'
9/14 7:39:32.653 3214 Srv: Remove Complete '\\?\SCSI#Disk&Ven_ROCKET&Prod_IMAGEFILE#1&1c121344&0&000001#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}'
9/14 7:39:40.915 35a4 Srv: Updating target 0000000001BC92B0 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-hyperv01', device list 'DDDisk1'...
9/14 7:39:40.915 35a4 Tgt: : parameter 'DataPath', value 'Data\E\XENVOL01.spdata'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'ImageSizeLow', value '0'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'ImageSizeHigh', value '256'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'MountStatus', value '2'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'MountProgress', value '1'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'MetadataPath', value 'Metadata\E\XENVOL01.spmetadata'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'BitmapPath', value 'My Computer\E\XENVOL01.spbitmap'.
9/14 7:39:40.915 35a4 Tgt: : parameter 'SnapshotsDisabled', value 'yes'.
9/14 7:39:40.915 35a4 Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-hyperv01'.
9/14 7:39:40.915 35a4 Tgt: iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-hyperv01: device DDDisk1: new LUN 0 mapped to target LUN 0.
9/14 7:39:40.915 35a4 Tgt: iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-hyperv01: attached device DDDisk1 (found 1 LUNs).
9/14 7:39:40.915 35a4 conf: Target [0x0000000001BC92B0] 'iqn.2008-08.com.starwindsoftware:sym-000125.symcominc.office-hyperv01' has been updated, 1 devices attached.
9/14 7:43:04.407 2b98 conf: Accepted control connection from 192.168.1.172:53022.
9/14 7:43:04.412 2b98 conf: Accepted control connection from 192.168.1.172:53023.
9/14 7:43:04.424 1ae4 conf: Send error 10053!
9/14 7:43:04.424 88c conf: Send error 10053!
9/14 7:43:04.424 88c conf: Control connection closed.
9/14 7:43:04.424 1ae4 conf: Control connection closed.
9/14 7:43:30.399 2b98 conf: Accepted control connection from 192.168.1.172:53025.
9/14 7:43:30.401 1358 conf: Control connection closed.
9/14 7:43:30.405 2b98 conf: Accepted control connection from 192.168.1.172:53026.
9/14 7:43:30.406 2f90 conf: Control connection closed.
9/14 7:43:30.411 2b98 conf: Accepted control connection from 192.168.1.172:53027.
9/14 7:43:30.412 4b40 conf: Control connection closed.
9/14 7:43:30.414 2b98 conf: Accepted control connection from 192.168.1.172:53028.
9/14 7:43:30.416 2328 conf: Control connection closed.
9/14 7:43:30.419 2b98 conf: Accepted control connection from 192.168.1.172:53029.
9/14 7:43:30.420 4150 conf: Control connection closed.
9/14 7:43:30.424 2b98 conf: Accepted control connection from 192.168.1.172:53030.
9/14 7:43:30.425 46e4 conf: Control connection closed.
9/14 7:43:30.428 2b98 conf: Accepted control connection from 192.168.1.172:53031.
9/14 7:43:30.428 24b4 conf: Control connection closed.
9/14 7:43:30.432 2b98 conf: Accepted control connection from 192.168.1.172:53032.
9/14 7:43:30.433 2418 conf: Control connection closed.
9/14 7:43:30.436 2b98 conf: Accepted control connection from 192.168.1.172:53033.
9/14 7:43:30.438 27d8 conf: Control connection closed.
9/14 7:43:30.441 2b98 conf: Accepted control connection from 192.168.1.172:53034.
9/14 7:43:30.443 3a9c conf: Control connection closed.
9/14 7:43:30.445 2b98 conf: Accepted control connection from 192.168.1.172:53035.
9/14 7:43:30.447 231c conf: Control connection closed.
9/14 7:43:30.449 2b98 conf: Accepted control connection from 192.168.1.172:53036.
9/14 7:43:30.452 fac conf: Send error 10053!
9/14 7:43:30.453 fac conf: Send error 10053!
9/14 7:43:30.453 fac conf: Control connection closed.
9/14 7:43:46.659 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53037 to 10.20.0.2:3260. (Id = 0x21)
9/14 7:43:46.659 3d14 C[21], FREE: Event - CONNECTED.
9/14 7:43:46.659 3d14 C[21], XPT_UP: T3.
9/14 7:43:46.660 3390 C[21], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.660 3390 C[21], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.663 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53038 to 10.20.0.2:3260. (Id = 0x22)
9/14 7:43:46.663 3d14 C[22], FREE: Event - CONNECTED.
9/14 7:43:46.663 3d14 C[22], XPT_UP: T3.
9/14 7:43:46.664 1da4 C[22], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.664 1da4 C[22], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.667 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53039 to 10.20.0.2:3260. (Id = 0x23)
9/14 7:43:46.667 3d14 C[23], FREE: Event - CONNECTED.
9/14 7:43:46.667 3d14 C[23], XPT_UP: T3.
9/14 7:43:46.668 1a80 C[23], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.668 1a80 C[23], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.671 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53040 to 10.20.0.2:3260. (Id = 0x24)
9/14 7:43:46.671 3d14 C[24], FREE: Event - CONNECTED.
9/14 7:43:46.671 3d14 C[24], XPT_UP: T3.
9/14 7:43:46.672 3edc C[24], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.672 3edc C[24], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.675 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53041 to 10.20.0.2:3260. (Id = 0x25)
9/14 7:43:46.676 3d14 C[25], FREE: Event - CONNECTED.
9/14 7:43:46.676 3d14 C[25], XPT_UP: T3.
9/14 7:43:46.676 3bf8 C[25], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.676 3bf8 C[25], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.680 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53042 to 10.20.0.2:3260. (Id = 0x26)
9/14 7:43:46.680 3d14 C[26], FREE: Event - CONNECTED.
9/14 7:43:46.680 3d14 C[26], XPT_UP: T3.
9/14 7:43:46.681 2784 C[26], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.681 2784 C[26], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.684 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53043 to 10.20.0.2:3260. (Id = 0x27)
9/14 7:43:46.684 3d14 C[27], FREE: Event - CONNECTED.
9/14 7:43:46.684 3d14 C[27], XPT_UP: T3.
9/14 7:43:46.684 3070 C[27], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.684 3070 C[27], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.688 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53044 to 10.20.0.2:3260. (Id = 0x28)
9/14 7:43:46.688 3d14 C[28], FREE: Event - CONNECTED.
9/14 7:43:46.688 3d14 C[28], XPT_UP: T3.
9/14 7:43:46.688 4848 C[28], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.688 4848 C[28], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.692 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53045 to 10.20.0.2:3260. (Id = 0x29)
9/14 7:43:46.692 3d14 C[29], FREE: Event - CONNECTED.
9/14 7:43:46.692 3d14 C[29], XPT_UP: T3.
9/14 7:43:46.692 2680 C[29], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.692 2680 C[29], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.695 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53046 to 10.20.0.2:3260. (Id = 0x2a)
9/14 7:43:46.695 3d14 C[2a], FREE: Event - CONNECTED.
9/14 7:43:46.695 3d14 C[2a], XPT_UP: T3.
9/14 7:43:46.696 15ac C[2a], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.696 15ac C[2a], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.699 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53047 to 10.20.0.2:3260. (Id = 0x2b)
9/14 7:43:46.699 3d14 C[2b], FREE: Event - CONNECTED.
9/14 7:43:46.699 3d14 C[2b], XPT_UP: T3.
9/14 7:43:46.700 3090 C[2b], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.700 3090 C[2b], FREE: *** 'recv' thread: recv failed 10058.
9/14 7:43:46.705 3d14 Srv: Accepted iSCSI connection from 192.168.1.172:53048 to 10.20.0.2:3260. (Id = 0x2c)
9/14 7:43:46.705 3d14 C[2c], FREE: Event - CONNECTED.
9/14 7:43:46.705 3d14 C[2c], XPT_UP: T3.
9/14 7:43:46.705 151c C[2c], XPT_UP: Login request excepted, got 0x10.
9/14 7:43:46.705 151c C[2c], FREE: *** 'recv' thread: recv failed 10058.
Sun Sep 16, 2012 6:27 am
I have a couple of questions that will help us to clarify the situation:
-are you evaluating SMI-S provider?
-what starwind build are you using?
-what starwind device type are you running?
jason.bashaw
Tue Sep 18, 2012 8:16 pm
Not sure what you are asking (the SMI-S threw me).
5.8.2060
deduplicated disk attached to iSCSI target
Tue Sep 18, 2012 8:27 pm
1) OK, so it's just StarWind Management console. Fine.
2) Please upgrade to V6 as 5.8 is outdated.
3) Please do 2) and let us know results (so we'd not hunt for something fixed a while ago).
jason.bashaw wrote:-are you evaluating SMI-S provider?
5.8.2060
jason.bashaw
Wed Sep 19, 2012 6:10 pm
Same result. This is the error I get in System Center:
IP address and port are valid.
Thu Sep 20, 2012 6:56 pm
May I ask you if you have got any AV software or FireWalls running?
