Problems installting on windows 2012 std core
Klas
Wed Aug 29, 2012 8:56 am
I get an error in a setup windows 'Not implemented'.
The server is a windows 2012 std core, try to install starwind server v6.0
Error installing on windows 2012
PS C:\Users\admin> get-service msiscsi
Status Name DisplayName
Running msiscsi Microsoft iSCSI Initiator Service
PS C:\Users\admin> Get-WindowsFeature -name *iscsi*
Display Name Name Install State
[ ] iSCSI Target Server FS-iSCSITarget-Server Available
[ ] iSCSI Target Storage Provider (VDS and V... iSCSITarget-VSS-VDS Available
Any ideas?
Klas
Wed Aug 29, 2012 11:08 am
Same error when i try to install lates build of 5.8.
Have anyone tried Starwind on windows 2012 core?
Bohdan (staff)
Wed Aug 29, 2012 12:47 pm
Klas wrote:Same error when i try to install lates build of 5.8.
Do not install StarWind Management Console on Core Windows versions where there is no Graphical Interface (Windows Explorer).
Select "StarWind iSCSI Service" installation type.
Install the StarWind Management Console on any non-Core machine and manage StarWind service remotely.
Klas
Thu Aug 30, 2012 8:06 am
We only try to install the server tools but get the error.
PS C:\storage> Get-WindowsFeature -name *gui*
[X] Graphical Management Tools and Infrastructure Server-Gui-Mgmt-Infra Installed
[ ] Server Graphical Shell Server-Gui-Shell Available
starwind error.gif (105.83 KiB) Viewed 17749 times
Thu Aug 30, 2012 8:17 am
Kind of strange... OK, let us check the stuff with our latest build. Thank you for your feedback!
Klas
Thu Aug 30, 2012 8:39 am
Ok, an explanation and solution should be great. We are aming on upgrading all of our hyper-v 2 node clusters to v6.
I enabled full gui on the 2012 server and after that the installer worked.
Might it be that the installer shecks if there is a "gui" on the server and then run the installation differently? If so, have you taken in account the different types of gui in 2012?
Thu Aug 30, 2012 8:46 am
Not really, shoud be some other component service is willing to have. Let us check...
Klas wrote:Ok, an explanation and solution should be great. We are aming on upgrading all of our hyper-v 2 node clusters to v6.
Klas
Thu Aug 30, 2012 9:47 am
New feature found :)
This is not our production nodes, just to test and verify stability of v6.0.
We have problems to configure HA. Seems like when though the option is available the setting is not accepted to run HB and sync on same NIC.
Bohdan (staff)
Thu Aug 30, 2012 10:09 am
Dedicated heartbeat channel is required.
I mean there must be at least two dedicated channels between each pair of HA nodes (one for "Sync and heartbeat" and one for "Heartbeat only").
The HA configuration with 2 Nodes should look like on the attached image.
But instead of 2 sync channels you can use one during testing.
The GUI warning message will be corrected.
