Cannot Launch StarWind Management Console
adhami03
Mon Apr 23, 2012 3:10 pm
I just installed StarWind iSCSI SAN on Windows Server 2003 R2 (32-bit) to try out the free edition. However, every time I try to open the StarWind Management Console, the following error window pops up:
WindStart Error.JPG (13.48 KiB) Viewed 26022 times
I took a look at the error log and it appears the service is running just fine:
The log file name: 'logs\starwind-20120423-104455.log'
4/23 10:44:55.093 d20 Srv: StarWind iSCSI SAN Software v5.8.0 (Build 20120307, [SwSAN], Win32)
4/23 10:44:55.093 d20 Srv: Built Mar 7 2012 22:40:42
4/23 10:44:55.093 d20 Srv: Windows Server 2003 R2 Enterprise Edition Service Pack 2 (Build 3790)
4/23 10:44:55.093 d20 Srv: System CPU count: 4
4/23 10:44:55.093 d20 Srv: CPU affinity mask 0xf from 0xf.
4/23 10:44:55.093 d20 Srv: License data not found.
4/23 10:44:55.093 d20 Srv: *** LICENSE NOT FOUND! ***
4/23 10:44:55.093 d20 Srv: Please contact StarWind Software at <support@starwindsoftware.com> for more details.
4/23 10:44:55.093 d20 Srv: Config file: 'StarWind.cfg'
4/23 10:44:55.109 d20 conf: Variable 'LogLevel' is set to '1'.
4/23 10:44:55.109 d20 conf: Variable 'LogMask' is set to '0x8fffffff'.
4/23 10:44:55.109 d20 conf: Variable 'UpdatePeriod' is set to '7'.
4/23 10:44:55.109 d20 conf: Variable 'UpdateHost' is set to 'www.starwindsoftware.com'.
4/23 10:44:55.109 d20 conf: Variable 'UpdatePage' is set to '/updatetracker/index.php'.
4/23 10:44:55.109 d20 conf: Variable 'UpdatePort' is set to '80'.
4/23 10:44:55.109 d20 conf: Variable 'UpdateCopyId' is set to '78A01DDB-5D2E-4294-A858A 55ED174137'.
4/23 10:44:55.109 d20 conf: Variable 'UpdateLastRequest' is set to '20120423'.
4/23 10:44:55.109 d20 conf: Variable 'Port' is set to '3260'.
4/23 10:44:55.109 d20 conf: Variable 'Interface' is set to '0.0.0.0'.
4/23 10:44:55.109 d20 conf: Variable 'BCastEnable' is set to 'yes'.
4/23 10:44:55.109 d20 conf: Variable 'BCastInterface' is set to '0.0.0.0'.
4/23 10:44:55.109 d20 conf: Variable 'BCastPort' is set to '3261'.
4/23 10:44:55.109 d20 conf: Variable 'Login' is set to 'root'.
4/23 10:44:55.109 d20 conf: Variable 'Password' is set to '##evVRsIJtRmAEEd2sCslZDg=='.
4/23 10:44:55.109 d20 conf: Variable 'MinBufferSize' is set to '65536'.
4/23 10:44:55.109 d20 conf: Variable 'AlignmentMask' is set to '0x0000'.
4/23 10:44:55.109 d20 conf: Variable 'MaxPendingRequests' is set to '64'.
4/23 10:44:55.109 d20 conf: Variable 'iScsiPingPeriod' is set to '0'.
4/23 10:44:55.109 d20 conf: Variable 'LocalizationDir' is set to 'Localizations'.
4/23 10:44:55.109 d20 conf: Variable 'DataBaseRoot' is set to '.\NotifyDB'.
4/23 10:44:55.109 d20 conf: Invalid variable 'DBRotationDays'.
4/23 10:44:55.109 d20 conf: Variable 'DBFileSizeDays' is set to '1'.
4/23 10:44:55.109 d20 conf: Variable 'PerformanceMonitorEnabled' is set to 'yes'.
4/23 10:44:55.109 d20 conf: Variable 'PerformanceRoot' is set to '.\PerformanceDB'.
4/23 10:44:55.109 d20 EventDB: wsRootDir = .\NotifyDB
4/23 10:44:55.125 d20 FileBrowser: Directory loaded: *|v|My Computer|*
4/23 10:44:55.125 d20 FileBrowser: Directory loaded: *|v|Image Files|img,dat
4/23 10:44:55.125 d20 FileBrowser: Directory loaded: *|cdmfv|Event Logs|txt,log
4/23 10:44:55.281 d20 Sw: DllMain: Initialize CDDS task descriptor...
4/23 10:44:55.281 d20 Sw: DllMain: CDDS task has has been reset: IsTaskScheduled: 0, SPStatus: 0
4/23 10:44:55.281 d20 Sw: DllMain: CDDS task descriptor has been initialized!
4/23 10:44:55.281 d20 Sw -> Browser_InitDirInfo: >>
4/23 10:44:55.281 d20 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|spbitmap'
4/23 10:44:55.281 d20 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'spbitmap'
4/23 10:44:55.281 d20 Sw <- Browser_InitDirInfo: return (0x1)
4/23 10:44:55.281 d20 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|Metadata|spmetadata'
Dirname: '*'
Rights: 0x1f
Alias: 'Metadata'
Extensions: 'spmetadata'
4/23 10:44:55.281 d20 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|Data|spdata'
Dirname: '*'
Rights: 0x1f
Alias: 'Data'
Extensions: 'spdata'
4/23 10:44:55.281 d20 Sw: SscPort_Init: (build 20120307, built Mar 7 2012 22:40:26)
VendorId = ' '
ProductId = ' '
Revision = '0001'
4/23 10:44:55.281 d20 conf: 'DDDisk.dll' loaded successfully.
4/23 10:44:55.343 d20 RAM: SscPort_Init: (build 20120307, built Mar 7 2012 22:40:19)
VendorId = ' '
ProductId = ' '
Revision = '0001'
4/23 10:44:55.343 d20 conf: 'RamDisk.dll' loaded successfully.
4/23 10:44:55.406 d20 Sw -> Browser_InitDirInfo: >>
4/23 10:44:55.406 d20 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|img'
4/23 10:44:55.406 d20 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Extensions: 'img'
4/23 10:44:55.406 d20 Sw <- Browser_InitDirInfo: return (0x1)
4/23 10:44:55.406 d20 IMG: SscPort_Init: (build 20120307, built Mar 7 2012 22:40:20)
VendorId = ' '
ProductId = ' '
Revision = '0001'
Volumes = 0
4/23 10:44:55.406 d20 conf: 'ImageFile.dll' loaded successfully.
4/23 10:44:55.468 d20 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
4/23 10:44:55.468 d20 conf: 'VirtualDvd.dll' loaded successfully.
4/23 10:44:55.468 d20 IBV: *SscPort_Init: Unused parameter: 'module'
4/23 10:44:55.468 d20 IBV: *SscPort_Init: Unused parameter: 'type'
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x1e
Alias: 'Snapshots'
Extensions: 'ibvss'
Dirname: '*'
Rights: 0x8
Alias: 'Database'
Extensions: 'ibvdb'
Dirname: '*'
Rights: 0x9
Alias: 'Image Files'
Extensions: 'img,dat'
4/23 10:44:55.468 d20 IBV: SscPort_Init: (build 20120307, built Mar 7 2012 22:40:22)
VendorId = ' '
ProductId = ' '
Revision = '0001'
ImageDir = '*\'
ExeDir = 'C:\Program Files\StarWind Software\StarWind\'
4/23 10:44:55.468 d20 conf: 'IBVolume.dll' loaded successfully.
4/23 10:44:55.546 d20 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Alias: 'Mirror Volumes'
Extensions: 'mir'
Dirname: '*'
Rights: 0x1f
4/23 10:44:55.546 d20 conf: 'Mirror.dll' loaded successfully.
4/23 10:44:55.546 d20 DSKBR: SscPort_Init: (built Mar 7 2012 22:40:22)
VendorId = ' '
ProductId = ' '
Revision = '0001'
4/23 10:44:55.546 d20 conf: 'DiskBridge.dll' loaded successfully.
4/23 10:44:55.609 d20 VTAPE: SscPort_Init: Parse ImageDir: '*|cmdfv|My Computer|vtl'
4/23 10:44:55.609 d20 VTAPE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'vtl'
4/23 10:44:55.609 d20 VTAPE: SscPort_Init: Comment : ''
4/23 10:44:55.609 d20 VTAPE: *** SscPort_Init: Logging level is set to 1.
4/23 10:44:55.609 d20 VTAPE: *** SscPort_Init: DBG_ERROR statements are ON.
4/23 10:44:55.609 d20 VTAPE: SscPort_Init: (built Sep 9 2010 11:28:35)
VendorId = ' '
ProductId = ' '
Revision = ' '
DefImageDir = '*\'
Volumes = 0
4/23 10:44:55.609 d20 VTAPE: *** TapeEmulCtrlApiStart: StarWind VTL License Type is 3
4/23 10:44:55.609 d20 VTAPE: *** TapeEmulCtrlApiStart: This Enterprise Edition supports a maximum of 64 devices, each up to 2097152 MB in length.
4/23 10:44:55.609 d20 conf: 'VirtualTape.dll' loaded successfully.
4/23 10:44:55.609 d20 HA: *SscPort_InitEx: Unused parameter: 'module'
4/23 10:44:55.609 d20 HA: *SscPort_InitEx: Unused parameter: 'type'
4/23 10:44:55.609 d20 Sw -> Browser_InitDirInfo: >>
4/23 10:44:55.609 d20 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|img'
4/23 10:44:55.609 d20 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Extensions: 'img'
4/23 10:44:55.625 d20 Sw <- Browser_InitDirInfo: return (0x1)
4/23 10:44:55.625 d20 HA: SscPort_InitEx: OS major version less or equel to 5, then will be used msinitiator transport.4/23 10:44:55.625 d20 HA: SscPort_InitEx: (build 20120307, built Mar 7 2012 22:40:20)
VendorId = ' '
ProductId = ' '
Revision = '0001'
DefImageDir = '*\'
Volumes = 0
4/23 10:44:55.625 d20 HA: CHADevice::InitializeModule: Params(p_hCxxLogger = 0x004A6750, p_pCallback = 0x0043CD41, p_hPluginHandle = 0x000D5230, p_ScsiTransportType = 2) ENTERed
4/23 10:44:55.625 d20 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: Check is exist old sessions with substring 'iqn.2008-08.com.starwindsoftware:' in initiator name...
4/23 10:44:55.625 d20 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: List of persistent login targets is empty.
4/23 10:44:55.625 d20 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: Old sessions are not found.
4/23 10:44:55.625 d20 conf: 'HAImage.dll' loaded successfully.
4/23 10:44:55.625 d20 conf: Reaction of type 'eventlog' [0x0000003E, 0x0C] loaded successfully.
4/23 10:44:55.625 d20 conf: Variable 'DefaultAccessPolicy' is set to 'allow'.
4/23 10:44:55.625 d20 Srv: Update tracker options: UpdatePeriod = 7, UpdateLastRequest = 20120423, UpdateHost = http://www.starwindsoftware.com, UpdatePage = /updatetracker/index.php, UpdatePort = 80, UpdateCopyId = 78A01DDB-5D2E-4294-A858A 55ED174137
4/23 10:44:55.625 d28 Srv: License data not found.
4/23 10:44:55.625 d20 Srv: Refreshing device list (complete)...
4/23 10:44:55.625 d20 SPTI: '\\?\scsi#disk&ven_dell&prod_container&rev_v1.0#4&318925a3&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'DELL Container V1.0': adapter 2, bus 4, target 0, LUN 0; maxTransferLength 65536, alignmentMask 0x0
4/23 10:44:55.625 d20 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 00000000, Record: 00000000).
4/23 10:44:55.625 d20 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
4/23 10:44:55.625 d20 SPTI: '\\?\scsi#disk&ven_dell&prod_container&rev_v1.0#4&318925a3&0&040100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'DELL Container V1.0': adapter 2, bus 4, target 1, LUN 0; maxTransferLength 65536, alignmentMask 0x0
4/23 10:44:55.625 d20 SPTI: '\\?\ide#cdromteac_cd-224e____________________________k.9a____#5&3125dc91&0&0.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' TEAC CD-224E K.9A': adapter 0, bus 0, target 0, LUN 0; maxTransferLength 131072, alignmentMask 0x1
4/23 10:44:55.625 d20 Srv: Found SPTI device '\\?\ide#cdromteac_cd-224e____________________________k.9a____#5&3125dc91&0&0.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' TEAC CD-224E K.9A'
4/23 10:44:55.640 d30 bc: Waiting for broadcast UDP packets at 0.0.0.0:3261...
4/23 10:44:55.640 d2c conf: Waiting for Control connections at 0.0.0.0:3261 ...
4/23 10:44:55.640 d20 Srv: Waiting for iSCSI connections at 0.0.0.0:3260 ...
4/23 10:44:55.640 d20 Srv: Waiting for iSCSI connections at 192.168.10.16:3260 ...
4/23 10:44:55.640 d20 Srv: Waiting for iSCSI connections at 127.0.0.1:3260 ...
Any ideas?
Mon Apr 23, 2012 4:50 pm
Try using some other Windows version to run Management Console @ this moment. We've never tried Windows 2003 R2 with the most recent builds (we'll do it with V5.9 once again). It does not affect running a service (as you've already noticied). Thanks!
adhami03
Mon Apr 23, 2012 5:11 pm
What's the link to download older/different version of StarWind? I can't find it on the main website.
adhami03
Mon Apr 23, 2012 6:35 pm
anton (staff) wrote:Try using some other Windows version to run Management Console @ this moment.
Ok, so I was able to install just the management console on a copy of Windows 7 and that seems to solve the issue for now. I was able to connect to the server and create a new iSCSI target for use with VMware ESXi. It would be nice to be able to launch the management console from the server, however.
Mon Apr 23, 2012 8:01 pm
Most people don't do it. I mean they don't use Windows 2003 and don't run management console in a loopback. However we'll fix this with V5.9 (test build is already present).
