free iSCSI initiator doesn't work
jps1x2
Tue Jun 14, 2011 5:54 pm
Hello again,
yesterday i downloaded iSCSI Initiator (iSCSIInitiatorSetup.exe) and installed on my windows xp professional sp3 with all patches applied using an administrator account.
Then following the manual (StarWind_iSCSI.pdf) connected to my Ubuntu (iscsitarget) and i created one iSCSI connected disk. That disk didn't appear in my disk management applet. When i tried to delete that connected disk on Starwind iSCSI applet i received a BSOD. Then uninstalled Starwind iSCSI initiator.
Tried to install Microsoft iSCSI initiator and connected ok to Ubuntu target, disk appear in my disk management applet and i can format it and use it.
Tried to connect to my iSCSI target using VirtualBox integrated iSCSI initiator and connects ok, i can run VMs from iSCSI.
Could you help me, please?
Microsoft iSCSI is very slow and i would like to test Starwind iSCSI initiator.
i have sent log file of use to admins.
Thanks in advance
Tue Jun 14, 2011 7:35 pm
What disk size do you export? Is it already initialized or not? When you launch Disk Management can you see anything there?
jps1x2
Wed Jun 15, 2011 11:53 am
I've collected all information in our mails:
15-06-2011 12:54 PM Anatoly пишет:
Hello jps1x2,
We saw the problem that caused your issue. Our R&D team is working on your bug now.
For now I can only suggest you to take continue work with our initiator and to decrease "stresses" on the target.
Thank you for understanding.
Support Engineer
StarWind Software Inc.
14.06.2011 20:59, jps1x2 пишет:
Hi Anatoly,
thanks for your reply, find enclosed log file of your iSCSI initiator from:
C:\Documents and Settings\...\Configuración local\Datos de programa\StarPort.log
I have posted again the problem i had.
yesterday i was registered using my mail of work and downloaded your application using this account.
I use this mail for forums, etc.
Thanks again
my iscsi target is not stressed, just use it for testing and is always idle.
Disk size 2 Gb:
root@ubuntuBck:/mnt/disco2/storage/# ls -la
-rw-r--r-- 1 root root  2097152000 2011-06-14 18:53 lun3.img
root@ubuntuBck:/mnt/disco2/storage/# cat /etc/ietd.conf
Target iqn.2011-06.mydomain:storage.lun3
MaxRecvDataSegmentLength 65536
MaxXmitDataSegmentLength 65536
IncomingUser
OutgoingUser
Lun 0 Path=/mnt/disco2/storage/lun3.img,Type=fileio
ALIAS LUN3
It is not initialized, i created file lun3.img on ubuntu and i would like to format it on windows with NTFS format using your iSCSI initiator. Created using following command:
dd if=/dev/zero of=/mnt/disco2/storage/lun3.img bs=1024k count=2000
Yes, all my physical disks and Ramdisk are there.
Thanks for your help
NOTE: Edited for adding iSCSI target info
Fri Jun 17, 2011 6:18 am
We've got your logs and detailed description of the issue. At the time our R&D team will be finding time slice to pinpoint and fix the issue I'd suggest you to proceed with working solution.
Thank you very much for cooperation! Your feedback is appreciated.
