I manually connect the iSCSI from Primary Server to its HA partner. It is connected but in Starwind Mgmt, it says the partner is not ready. When I view the iSCSI session of the partner, I see the connection that I just did.
In the log, it says
2/22 11:10:02.593 15e8 HA: CMSInitiatorDevice::SendCustomControlScsiCommand: EXITing with failure, device not mounted or not opened (m_hDevice == INVALID_HANDLE_VALUE)!
2/22 11:10:02.593 15e8 HA: HA_SendCustomControlScsiCommand: EXITing with failure, pDevice->SendCustomControlScsiCommand(..) failed!
How should I correct this?
Thanks.
