Bill.French
Mon Feb 07, 2011 3:56 pm
Hello. I really need some help. I'm getting "Device Access is Denied" when trying to connect to a Coraid AoE device. Coraid says everything looks ok, and that there's nothing in their system to prevent a server from connecting. The coraid unit is directly connected over ethernet (no switch or anything else involved) to a dedicated ethernet port. It has worked for years.
The logs for the AoE initiator don't seem to have anything interesting in them at all:
2/6 19:35:35 a04 ntsrv: StarAoE Service v5.5 (Build 20091120, WinXP x86)
2/6 19:35:35 a04 Srv: No bound volumes found.
2/6 19:35:35 a04 Srv: Service started.
Mon Feb 07, 2011 8:44 pm
1) Make sure you have StarEther driver started and listed as available protocol for NIC you're routing AoE traffic with.
2) If 1) is OK please install Wireshark and gather Ethernet traffic logs for connection attempt.
Bill.French
Tue Feb 22, 2011 3:20 pm
i found and reinstalled an older version of starport and that seemed to fix the issue. The newest version of the aoe initiator could not connect from 3 different systems.
Tue Feb 22, 2011 4:22 pm
Does not sound like a good idea to me. Absolutely. Old versions have own issues so we'd better fix the most recent one rather then finding a workaround.
Bill.French wrote:i found and reinstalled an older version of starport and that seemed to fix the issue. The newest version of the aoe initiator could not connect from 3 different systems.
