Performance Monitor and iSCSI
hixont
Tue Dec 14, 2010 10:32 pm
Given a recent sync channel failure I found my SAN out of sync and both sides thought they were synchronized. Is it possible to utilize Performance Monitor to determine which iSCSI targets are the "active" target when a disconnect of this nature occurs in order to determine which (server) side of the target is actually the synchronized/in use target? I have a two node HA configuration with nine HA targets.
P.S. I had an upgrade scheduled to go to 5.5 this Friday which has now been bumped forward following this issue.
Constantin (staff)
Wed Dec 15, 2010 10:04 am
1. You can see in SMC amount of iSCSI connections - the most secure way to see if node is synchronized
2. You can see it in status window (right down side) - second most secure way to see if node is synchronized
3. If you use RoundRobin both servers are active, until one of them will go out of sync :)
