nycon1
Thu Dec 02, 2010 12:37 pm
Hello.
I want to know if my hardware config is right:
SAN1
Starwind 5.4
HP DL180G6
Xeon quad core 2,2
6 GB of memory
5 hd SATA 7.2 RPM RAID 5
8 nics Gbe Intel (2 for sync/6 for ESX Access)
Jumbo Frames Activated
Last drivers on nics
SAN1
Starwind 5.4
HP DL180G6
Xeon quad core 2,2
6 GB of memory
2 nics Gbe Intel (1 for sync/1 for ESX Access)
Copy of any file in virtual machines is 1-2 MB/s, same VM´s on Openfiler 40 MB/s.
2 Switch Procurve 1810G with Jumbo Frames activated.
Jumbo Frames activated on ESX 4.1.
Any idea?
Max (staff)
Thu Dec 02, 2010 1:00 pm
StarWind HA is a Synchronous solution while Openfiler is just a virtual IP failover.
1. Make your configuration synchronous (equal amount of NICs on both servers)
2. If there is an option - avoid using raid3-4-5 unless you're more paranoid about your data then about your performance.
3. Turn off the Jumboframes
4. Ensure that your HA is configured properly
Max Kolomyeytsev
nycon1
Thu Dec 02, 2010 3:20 pm
thank you for fast response.
RAID1 is the most properly option?
Where turn off the Jumboframes, on ESX, on SAN, on switch, all?
Thank you for all.
Max (staff)
Thu Dec 02, 2010 4:35 pm
The best RAID level will be one which delivers the best performance.
Jumboframes should be switched off everywhere.
Max Kolomyeytsev
nycon1
Thu Dec 02, 2010 7:58 pm
In this post: TCP/IP stack optimized iSCSI settings, says how to switch on Jumboframes for optimize iSCSI
I don´t understand.
Thanks.
Max (staff)
Fri Dec 03, 2010 3:25 pm
In some cases the optimization can work the opposite way
In the 5.5 we have made some tweaks to increase the throughput on regular networks, however those sometimes interfere with the JF's and modified TCP stack.
Max Kolomyeytsev
awedio
Fri Dec 03, 2010 3:59 pm
Max (staff) wrote:..Jumbo frames should be switched off everywhere.
Is this a new rule? or is this related to OpenFiler + ESX only?
Max (staff)
Fri Dec 03, 2010 6:10 pm
awedio wrote:Is this a new rule? or is this related to OpenFiler + ESX only?
This is for the particular case only, I can't tell anything about Openfiler tweaks
Max Kolomyeytsev
