wageningen
Wed Aug 11, 2010 2:03 pm
I’m getting the following error while converting the VHD file to an ESX .vmdk file: File I/O error (4)
The source is from a Windows 2008 R2 physical server.
The VHD file created by disk2vhd.exe, from sysinternals.
The target format is: .vmdk VMware ESX server
The disk is 136 GB, but I only selected the C (system) partition to be converted.
The VHD file is 12 GB, but when I convert it to .vmdk format it wants to make the file 136 GB.
Wed Aug 11, 2010 4:16 pm
You have an error I would not expect OS to throw...
// MessageId: ERROR_TOO_MANY_OPEN_FILES
// MessageText:
// The system cannot open the file.
#define ERROR_TOO_MANY_OPEN_FILES 4L
And V2V wants to create full 136GB file b/c VMDK (generic form) does not support sparse images. But we'd take a look at the software you list, will try to reproduce the issue here to see what could be dome to avoid it. We'll keep you updated. Thanks!
wageningen
Fri Aug 13, 2010 12:27 pm
Oke thanx.
I also executed another method: Online backup of the Windows 2008 R2 server with the standard backup tool.
This is also creating an .VDH file. I've converted this to a .vmdk file and it succesfully created an 40 GB file (instead of 136 GB). Created a virtual machine and attached the .vmdk file. After I configured 8 CPU's it stared up, but no OS, only reguesting an IP adres of DHCP.
Fri Aug 13, 2010 4:33 pm
You need to configure other emulated hardware. VMware and Microsoft emuate very different hardware so 99% the OS is not going to boot unless you'll do proper hardware migration.
