My first post here. I have been trying out starwind in trial and i must say i am very impressed with its ease of use and performance
1) If i understood correctly, with write-back cache enabled, if the SAN fail (hardware failure , etc) there is good chance (or its 100% sure) that the data in the .img file or the physical disk if using disk bridge, will be corrupted?
2) But using cache is appealing for performances, and i recall having read on this forum that with HA configuration, with write-back cache, if one node fail, the data is still "clean" on the other node? What happen if the data being written is cached on the node that fails? Is this also true with raid-1 (mirror) target?
3) Is there any way to tell starwind to use all RAM available on the system and use it for write-back cache as it wishes among all the target configured?
4) Is there any ways to modify cache settign on a target without re-creating that same target (or modifying .cfg + service restart)
5) LUN ID in vmware, I just read the post where anton mention we should be able to configure this in v5.4 but i am not sure where to configure this in the console
Thanks in advance!
Seb
