Error converting from vhd to .vmdk (Esxi)
maz124s
Fri Dec 04, 2009 12:28 am
Hi
I was wondering if anyone could help with me with this problem, i recently started using your Convertor V2V program, i found a major issue with when converting vhd images to vmware esxi format, the conversion works fine and then i upload the new .vmdk file into a datastore, which is seemingly completes fine and is displayed as being there in the datastore
When I then go to add the .vmdk as a hard disk it is then not recognised and it is missing
I have tried this with multiple vhd files with the same result can you shed any light on why this is occurring?
Sat Jan 16, 2010 6:44 pm
Can you send us a screenshot and provide with a link to sample failing image container?
wlawn
Mon Aug 09, 2010 3:27 pm
Did you ever find a solution to your issue? I have the same problem.
Thanks.
Mon Aug 09, 2010 6:40 pm
There were issues with sparse VMDK files. Are you using the most recent version of V2V Converter software?
wlawn wrote:Did you ever find a solution to your issue? I have the same problem.
Thanks.
rolandocgs
Thu Mar 24, 2011 3:10 pm
Actually I just posted a new topic of this problem and I am sorry I didn't find this topic opened before but this is the same issue I had when I did a pre-allocated image it just didn't show but when I did the growable image it showed and allowed me to use it as a hard disk but then failed when I ran the virtual machine.
Thu Mar 24, 2011 4:16 pm
Use pre-allocated.
rolandocgs wrote:Actually I just posted a new topic of this problem and I am sorry I didn't find this topic opened before but this is the same issue I had when I did a pre-allocated image it just didn't show but when I did the growable image it showed and allowed me to use it as a hard disk but then failed when I ran the virtual machine.
