Should it work on 2008 R2 (x64) for AoE?
Bill.French
Mon Nov 02, 2009 1:53 pm
Trying to connect to a coraid device, but getting the following error:
(Basically, "Driver failure.")
Thanks!!
Robert (staff)
Mon Nov 02, 2009 3:14 pm
Bill,
Please make sure that a volume (LUN) is already created on your AoE device.
Also, try checking "force configuration string" checkbox.
Thanks.
Robert
StarWind Software Inc.
Bill.French
Mon Nov 02, 2009 3:52 pm
Hmm... doing the "force configuration string" seemed lock the system; ctrl-alt-delete does not work. I reset it and the drive shows up in drive manager but I can't do anything with it; i tried to remove it and that locked the system, too. Any other suggestions?
This is all under ESX, for what it's worth; i wouldn't think that would make a difference but perhaps it does. Thanks!
Robert (staff)
Thu Nov 05, 2009 4:31 pm
I would recommend trying that on a physical machine since virtual machines can sometimes show a similar behaviour in the current build series.
Robert
