not able to use bridgedevice
fredvr
Wed Aug 05, 2009 12:38 pm
Hi
just created a 1Tb SAS disk as a bridge device. Looks like everything went smooth. no errors and it looks like available.
on a client server I try to mount to that iScsi device. The device is listed but when I try to mount to it I got an error:
- ms initiator -> service not available
- starpoint ('remote iscsi') -> no description available. an error occured during installation of the device
looks like a problem in the diskbridge device.
using the most recent downloaded and licenced Starwind Server software.
mounting a created imagefile device from\to the same systems seems to work fine.
Robert (staff)
Fri Aug 07, 2009 10:31 am
Make sure that the port 3260 (TCP) on the StarWind side is opened in the firewall settings. Also, please add StarWind to the exception list in the firewall.
Thanks.
Robert
StarWind Software Inc.
fredvr
Fri Aug 07, 2009 2:08 pm
Hi Robert
Don't think this is causing the issue
As mentioned
They are using the same ports.
bboule
Sat Aug 08, 2009 12:38 pm
Would you mind sending your StarWind log files (C:\Program Files\StarWind Software\StarWind\logs\) to bob.boule@starwindsoftware.com Once I have had a chance to review your logs I should be able to get you back on track!
Bob
fredvr
Wed Aug 12, 2009 12:11 pm
Hi Bob
You should have received the logs last Tuesday!
K.Regards
Robert (staff)
Mon Aug 17, 2009 12:33 pm
So, I suppose we're all set with this one?
The issue was related to giving a target name to a diskbrodge device.
Robert
