Cannot add device.
mihai.gabriel
Tue Mar 24, 2009 10:44 am
Hello.
I am having some problems in adding a new device with StarWind 4.0. Whatever type of device i try to add, i always get the same error at the end of the process:
"Cannot add device. Device test failed for 'DiskBridge0'." The text with DiskBridge0 is the only one that changes, depending on what device i am trying to add (RamDrive0 etc).
This isn't the first time i use StarWind, last time it functioned without this problem. The only difference is that now i am using a 64 bit Windows Server 2003 R2 Enterprise. Last time i used the 32 bit version.
Can you tell me what i am doing wrong?
Thank you,
Gabi Constantin.
Robert (staff)
Tue Mar 24, 2009 1:49 pm
Gabi,
Please send us the log files from C:\Program Files\Starwind Software\Starwind\logs to support@starwindsoftware.com
We will do our best to figure out the root cause of this.
Rob
Robert
StarWind Software Inc.
