MS Cluster not failing over with hard shutdown
romanek
Fri Feb 13, 2009 8:33 pm
I just installed 2 nodes cluster for a test, I am using a trial version (3.5.4)
If I do a Graceful shutdown in the active node, the other node becomes active
If I do a Hard shutdown in the active node, the other node doesn´t become active
In the starwind log I saw: 2/13 14:25:39.306 db4 PR: Std: S[4] ScsiOp 0x28 - Reservation conflict.
I already tried to change the following parameter in StarWind.cfg and I restarted the service:
from <iScsiPingPeriod value="0"/>
to <iScsiPingPeriod value="5"/>
But the cluster service doesn't go up and I have to wait some minutes to force a start up ... and then It works.
Is there something to fix it ?
Best Regards
Romanek
Robert (staff)
Mon Feb 16, 2009 11:04 am
Hello Romanek,
Please download and install the latest version (just released) of StarWind 4.0 http://www.starwindsoftware.com/starwin ... -iscsi-san
Reinstall the application and let us know whether or not the problem still persists.
Rob
Robert
StarWind Software Inc.
romanek
Mon Feb 16, 2009 4:19 pm
Hi Rob,
I installed this last version and I returned the default value (<iScsiPingPeriod value="0"/>) and It is working perfect !
Thank you for your help !!
Romanek
Corpse
Tue Feb 17, 2009 1:58 pm
The new version just rocks! It's got lots of fixes and functionality improvements!
Robert (staff)
Tue Feb 17, 2009 2:02 pm
romanek wrote:Hi Rob,
Romanek
Hello Romanek,
I'm glad the issue is resolved.
Please feel free to post and contact us at http://www.starwindsoftware.com/support should you have any questions
Rob
Robert
