Windows 2008 starwind gui unable to connect
ipctecho
Mon Jan 12, 2009 6:07 am
I am getting the following error when I try to connect with the starwind GUI locally.
"An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full."
This appears after a while, and a reboot of the machine fixes it then it happens again. Also unable to browse windows file shares when this happens.
I have disabled ipv6 which MS seems to favour as a way to fix this isssue.
Also if I do a netstat -an I see thousands of UDP connections that are in listening state and connecting to 0.0.0.0 as if the udp connections are not being cleared down.
v3.5.5 installed on windows 2008 no other third party software installed.
iSCSI targets still work fine to this machine when in this state.
Mon Jan 12, 2009 11:49 am
We don't use UDP rather TCP only. So I'm afraid it's something else and not StarWind who creates this mess. Try to get process names using nstat.
ipctecho
Tue Jan 13, 2009 12:09 am
Thanks for the info I will check elsewhere.
What about the error connecting to the GUI, any ideas about it?
Tue Jan 13, 2009 4:57 pm
System running low on non-paged memory for network stack.
ipctecho wrote:Thanks for the info I will check elsewhere.
