*ERROR* IBVolume_CreateInternal:
lndisk
Fri Dec 19, 2008 2:51 am
12/19 10:41:21 74c Srv: *** TRIAL VERSION *** [ expires in 15 day(s) ]
12/19 10:41:21 74c Srv: Please contact Rocket Division Software at <info@rocketdivision.com> for more details.
12/19 10:41:21 74c Srv: Unlimited number of client hosts allowed.
12/19 10:41:21 74c Srv: Config file: 'C:\Program Files\Rocket Division Software\StarWind\starwind.conf'
12/19 10:41:21 74c conf: 'LogLevel' = '1'
12/19 10:41:21 74c conf: 'LogMask' = '0x8fffffff'
12/19 10:41:21 74c conf: 'Port' = '3260'
12/19 10:41:21 74c conf: 'Interface' = '0.0.0.0'
12/19 10:41:21 74c conf: 'DefTargetName' = 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'
12/19 10:41:21 74c conf: 'Login' = 'test'
12/19 10:41:21 74c conf: 'Password' = '##CY9rzUYh03PK3k6DJie09g=='
12/19 10:41:21 74c conf: 'Echo' = 'no'
12/19 10:41:21 74c conf: 'MinBufferSize' = '65536'
12/19 10:41:21 74c conf: 'AlignmentMask' = '0x0000'
12/19 10:41:21 74c conf: 'MaxPendingRequests' = '64'
12/19 10:41:21 74c conf: Variable 'LogLevel' is set to '1'.
12/19 10:41:21 74c conf: Variable 'LogMask' is set to '0x8fffffff'.
12/19 10:41:21 74c conf: Variable 'Port' is set to '3260'.
12/19 10:41:21 74c conf: Variable 'Interface' is set to '0.0.0.0'.
12/19 10:41:21 74c conf: Variable 'DefTargetName' is set to 'iqn.2003-06.com.rocketdivision.starwind:$(host).$(symid)'.
12/19 10:41:21 74c conf: Variable 'Login' is set to 'test'.
12/19 10:41:21 74c conf: Variable 'Password' is set to '##CY9rzUYh03PK3k6DJie09g=='.
12/19 10:41:21 74c conf: Variable 'Echo' is set to 'no'.
12/19 10:41:21 74c conf: Variable 'MinBufferSize' is set to '65536'.
12/19 10:41:21 74c conf: Variable 'AlignmentMask' is set to '0x0000'.
12/19 10:41:21 74c conf: Variable 'MaxPendingRequests' is set to '64'.
12/19 10:41:21 74c conf: 'RamDisk.dll' loaded successfully.
12/19 10:41:21 74c IMAGE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img,dat'
12/19 10:41:21 74c conf: 'ImageFile.dll' loaded successfully.
12/19 10:41:21 74c VDVD: *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
12/19 10:41:21 74c conf: 'VirtualDvd.dll' loaded successfully.
12/19 10:41:21 74c IBV: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x18
Alias: 'Readonly ImageFiles'
12/19 10:41:21 74c conf: 'IBVolume.dll' loaded successfully.
12/19 10:41:21 74c S: the device 'IBV0' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '001', SymId: 'IBV.IBV0'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk1.ibv'.
12/19 10:41:21 74c S: parameter 'mode', value '3'.
12/19 10:41:21 74c S: parameter 'JournalSwitchPeriod', value '0'.
12/19 10:41:21 74c S: parameter 'ImageSizeLow', value '0'.
12/19 10:41:21 74c S: parameter 'ImageSizeHigh', value '250'.
12/19 10:41:21 74c S: parameter 'CurrentMode', value '3'.
12/19 10:41:21 74c S: parameter 'LastSessionId', value '1'.
12/19 10:41:21 74c S: parameter 'BaseImageFile', value 'f:\1000G.IMG'.
12/19 10:41:21 74c S: 001: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x940f0] has been created. Device 'IBV0' is accesible as target '001'.
12/19 10:41:21 74c S: the device 'IBV1' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '002', SymId: 'IBV.IBV1'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk2.ibv'.
12/19 10:41:21 74c S: 002: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x96818] has been created. Device 'IBV1' is accesible as target '002'.
12/19 10:41:21 74c S: the device 'IBV2' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '003', SymId: 'IBV.IBV2'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk3.ibv'.
12/19 10:41:21 74c S: 003: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x942a0] has been created. Device 'IBV2' is accesible as target '003'.
12/19 10:41:21 74c S: the device 'IBV3' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '004', SymId: 'IBV.IBV3'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk4.ibv'.
12/19 10:41:21 74c S: 004: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x94a90] has been created. Device 'IBV3' is accesible as target '004'.
12/19 10:41:21 74c S: the device 'IBV4' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '005', SymId: 'IBV.IBV4'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk5.ibv'.
12/19 10:41:21 74c S: 005: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x95418] has been created. Device 'IBV4' is accesible as target '005'.
12/19 10:41:21 74c S: the device 'IBV5' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '006', SymId: 'IBV.IBV5'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk6.ibv'.
12/19 10:41:21 74c S: 006: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x95c08] has been created. Device 'IBV5' is accesible as target '006'.
12/19 10:41:21 74c S: the device 'IBV6' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '007', SymId: 'IBV.IBV6'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk7.ibv'.
12/19 10:41:21 74c S: 007: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x97090] has been created. Device 'IBV6' is accesible as target '007'.
12/19 10:41:21 74c S: the device 'IBV7' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '008', SymId: 'IBV.IBV7'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk8.ibv'.
12/19 10:41:21 74c S: 008: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x988a8] has been created. Device 'IBV7' is accesible as target '008'.
12/19 10:41:21 74c S: the device 'IBV8' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '009', SymId: 'IBV.IBV8'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk9.ibv'.
12/19 10:41:21 74c S: 009: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x97210] has been created. Device 'IBV8' is accesible as target '009'.
12/19 10:41:21 74c S: the device 'IBV9' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '010', SymId: 'IBV.IBV9'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk10.ibv'.
12/19 10:41:21 74c S: 010: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x97a00] has been created. Device 'IBV9' is accesible as target '010'.
12/19 10:41:21 74c S: the device 'IBV10' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '011', SymId: 'IBV.IBV10'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk11.ibv'.
12/19 10:41:21 74c S: 011: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x99030] has been created. Device 'IBV10' is accesible as target '011'.
12/19 10:41:21 74c S: the device 'IBV11' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '012', SymId: 'IBV.IBV11'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk12.ibv'.
12/19 10:41:21 74c S: 012: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x9a860] has been created. Device 'IBV11' is accesible as target '012'.
12/19 10:41:21 74c S: the device 'IBV12' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '013', SymId: 'IBV.IBV12'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk13.ibv'.
12/19 10:41:21 74c S: 013: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x99178] has been created. Device 'IBV12' is accesible as target '013'.
12/19 10:41:21 74c S: the device 'IBV13' is opened successfully.
12/19 10:41:21 74c S: Assigned target name: '014', SymId: 'IBV.IBV13'.
12/19 10:41:21 74c S: parameter 'file', value 'My Computer\d\netdisk\disk14.ibv'.
12/19 10:41:21 74c S: 014: 1 session(s) allowed.
12/19 10:41:21 74c conf: Target [0x99970] has been created. Device 'IBV13' is accesible as target '014'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk15_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk15.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV14' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV14'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV14'.
12/19 10:41:21 74c conf: Device test failed for 'IBV14'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk16_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk16.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV15' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV15'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV15'.
12/19 10:41:21 74c conf: Device test failed for 'IBV15'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk17_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk17.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV16' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV16'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV16'.
12/19 10:41:21 74c conf: Device test failed for 'IBV16'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk18_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk18.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV17' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV17'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV17'.
12/19 10:41:21 74c conf: Device test failed for 'IBV17'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk19_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk19.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV18' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV18'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV18'.
12/19 10:41:21 74c conf: Device test failed for 'IBV18'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk20_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk20.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV19' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV19'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV19'.
12/19 10:41:21 74c conf: Device test failed for 'IBV19'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk21_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk21.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV20' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV20'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV20'.
12/19 10:41:21 74c conf: Device test failed for 'IBV20'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk22_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk22.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV21' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV21'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV21'.
12/19 10:41:21 74c conf: Device test failed for 'IBV21'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk23_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk23.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV22' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV22'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV22'.
12/19 10:41:21 74c conf: Device test failed for 'IBV22'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk24_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk24.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV23' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV23'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV23'.
12/19 10:41:21 74c conf: Device test failed for 'IBV23'.
12/19 10:41:21 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk25_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:21 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk25.ibv') error (0xc0000001)!
12/19 10:41:21 74c SCSI: Failed to create 'IBV24' device.
12/19 10:41:21 74c S: *ERROR* cannot open the device 'IBV24'.
12/19 10:41:21 74c Srv: * Device test failed for 'IBV24'.
12/19 10:41:21 74c conf: Device test failed for 'IBV24'.
12/19 10:41:22 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk26_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:22 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk26.ibv') error (0xc0000001)!
12/19 10:41:22 74c SCSI: Failed to create 'IBV25' device.
12/19 10:41:22 74c S: *ERROR* cannot open the device 'IBV25'.
12/19 10:41:22 74c Srv: * Device test failed for 'IBV25'.
12/19 10:41:22 74c conf: Device test failed for 'IBV25'.
12/19 10:41:22 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk27_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:22 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk27.ibv') error (0xc0000001)!
12/19 10:41:22 74c SCSI: Failed to create 'IBV26' device.
12/19 10:41:22 74c S: *ERROR* cannot open the device 'IBV26'.
12/19 10:41:22 74c Srv: * Device test failed for 'IBV26'.
12/19 10:41:22 74c conf: Device test failed for 'IBV26'.
12/19 10:41:22 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk28_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:22 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk28.ibv') error (0xc0000001)!
12/19 10:41:22 74c SCSI: Failed to create 'IBV27' device.
12/19 10:41:22 74c S: *ERROR* cannot open the device 'IBV27'.
12/19 10:41:22 74c Srv: * Device test failed for 'IBV27'.
12/19 10:41:22 74c conf: Device test failed for 'IBV27'.
12/19 10:41:22 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk29_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:22 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk29.ibv') error (0xc0000001)!
12/19 10:41:22 74c SCSI: Failed to create 'IBV28' device.
12/19 10:41:22 74c S: *ERROR* cannot open the device 'IBV28'.
12/19 10:41:22 74c Srv: * Device test failed for 'IBV28'.
12/19 10:41:22 74c conf: Device test failed for 'IBV28'.
12/19 10:41:22 74c IBV: *ERROR* IBVolume_CreateInternal: 'd:\netdisk\disk30_00000001.ibvm': MapViewOfFile (err: 8).
12/19 10:41:22 74c IBV: *ERROR* SscPort_Create: Create('My Computer\d\netdisk\disk30.ibv') error (0xc0000001)!
12/19 10:41:22 74c SCSI: Failed to create 'IBV29' device.
12/19 10:41:22 74c S: *ERROR* cannot open the device 'IBV29'.
12/19 10:41:22 74c Srv: * Device test failed for 'IBV29'.
12/19 10:41:22 74c conf: Device test failed for 'IBV29'.
12/19 10:41:22 74c Srv: Refreshing device list (complete)...
Fri Dec 19, 2008 3:39 pm
Would you PLEASE send COMPLETE log and your actions descriptions to support@rocketdivision.com as the one you've posted here is truncated in the most interesting place. Thank you!
