I hope that I don't miss my request in the FAQ.
I explain my issue.
From a VMWARE server (free version 1.0.3), I installed two windows 2008 server (64 bit version) to build a cluster (for a test).
I follow step by step your documentation "Starwind isci targer for microsoft Windows:Using starwind with microsoft cluster on windows server 2008" ( firstly, it's a superb documentation).
I installed the starwind software (version 3.5.5 trial version 64 bit) on the first server (node 1) .
The second server (node 2) can join the iscsi target.(with firewall disable on the both server)
All was perfect, but on the page 67 of 96, the documentation requires to shut down the server node 2.
Since I did it, the server node 2 is unable to connect on iscsi target.
the message in "iscsi initiator" is "reconnecting".
I remove the iscsi target from the iscsi initiator, and tried to repeat the steps of page 55 to 61 without success.
I disconnect on server 1 the iscsi target on server 1, I removed the starwind device on the server 1, and repeat again all process to create starwind device on server 1.
From the server 1, I can connect the starwind device from iscsi initiator, but impossible from server 2. (the firewall are devalided on the both server).
Have you an idea about this issue?
could you tell me where I should have a look?
Thanks for your support
regards
Fabien
