StarWind and RESERVE/RELEASE?
mprowe
Sun May 18, 2008 12:47 pm
I note that in the FAQ (Q18) http://www.rocketdivision.com/faq.html?pr_id=2 that for devices connected with the SPTI,
StarWind should redirect all RESERVE/RELEASE op-codes directly to the device.
However, I'm not sure that this is happening?
I am using StarWind 3.5.1 and StarPort 3.5.4 and the following screen shot shows a device analyser monitoring
the Initiator (left side tab, addrs = .2) and the Target (right side tab, addrs= .3).
The Initiator has issued a series of SCSI CDBs and these IO requests have been trapped and displayed.
I think I see that the Initiator has issued a Reserve/Release pair (counter 6 & 13 - highlighted).
However, these commands are not reflected at the Target? Where have they gone?
First thoughts - Initiator or Target problem? So I watch the network between the two. This next screen shot shows that trace.
From this, I conclude that the Reserve/Release op-codes are leaving the Initiator and are, in fact are being acknowledged by the Target (counters 1228/9 & 1278/9 - highlighted).
Working from this information, I have to conclude that the StarWind service is taking it upon itself to handle the Reserve/Release commands - contrary to FAQ, Q18?
Any advice that would reconcile/correct this option will be much appreciated.
Martin
Sun May 18, 2008 1:56 pm
Before Valery will take a closer look I have a question: are you trying to reserve/release a scanner?
mprowe
Mon May 19, 2008 6:27 am
Hi Anton, …. Are you psychic? Or is it just a good memory<grin>?
Unfortunately, we Bsc students don’t have the luxury to become disinterested ;-) gota come up with some sort of conclusion, you know!
Martin
Val (staff)
Mon May 19, 2008 10:38 am
Hi Martin,
You are right, the recent StarWind core process reserve/release operations internally for all targets by default.
It's okay for all the virtual device modules, but for such cases with SPTI-mapped devices the internal processing of reservation commands can be switched off.
1) Open StarWind.cfg in notepad and find the SPTI-device you want to disable internal reservation processing.
2) Add 'reservation="no"' to the list of the device's parameters.
3) Restart the StarWindService.
After that the SPTI device should receive the reservation SCSIOPs.
Valeriy
Mon May 19, 2008 7:08 pm
No I'm not. You just have UMAX Astra 22xx listed as conneted to the StarPort Storage Controller. Your own screenshot :)
Martin
