creation of the iscsi device failed with all the addresses..
Locked
galonga
Wed Mar 05, 2008 11:38 pm
Hi folks
We downloaded yesterday both starport and starwind and installed them with the licenses you supplied to us.
We created a .img 18 Gb image file and mounted it correctly in 1 PC.
However, if we try to mount in another PC another we get the message:
"creation of the iscsi device failed with all the addresses supplied by the server"
We also tried with microsoft´s iscsi software to no avail
We never had those problems and we wonder if it´s the new versions?
thanks!
al costa
kviar.com
rio de janeiro
brazil
Thu Mar 06, 2008 6:32 pm
Send us StarWind log. It's impossible to tell the reason w/o it.
galonga
Sun Mar 09, 2008 8:42 pm
I´m sending it over email in zipped format as requested in this forum
3/9 18:17:42.774 >> CLanguager::LoadLanguage(language=0x409)
3/9 18:17:42.894 << CLanguager::LoadLanguage(language=0x409)
3/9 18:17:42.894 Failed to query registry ShowSplash value.
3/9 18:17:42.894 CStarPortApp::CheckLicense: License data not found.
3/9 18:17:42.905 CStarPortApp::CheckLicense: *** TRIAL VERSION *** [ expires in 30 day(s) ]
3/9 18:17:44.507 >> CStarPortAPI::CStarPortAPI()
3/9 18:17:44.507 >> CStarPortAPI::DriverOpen()
3/9 18:17:44.507 << CStarPortAPI::DriverOpen()
3/9 18:17:44.507 >> CStarPortAPI::DriverVersion(...)
3/9 18:17:44.507 CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
3/9 18:17:44.507 CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
3/9 18:17:44.507 CStarPortAPI::DriverVersion: Input: ApiVersion = 30001
3/9 18:17:44.507 CStarPortAPI::DriverVersion: Output: Version = 20080111, API = 30001, DriverOpenContext = 0, DriverInstance = FFFFFFFF82F58B88
3/9 18:17:44.507 << CStarPortAPI::DriverVersion(...)
3/9 18:17:44.517 CStarPortAPI::CStarPortAPI: StarPort version: 20071025; StarPort driver: API v30001, Build 0x20080111
3/9 18:17:44.517 << CStarPortAPI::CStarPortAPI()
3/9 18:17:44.517 >> CDriveLetterMap::CDriveLetterMap()
3/9 18:17:44.517 << CDriveLetterMap::CDriveLetterMap()
3/9 18:17:44.517 >> CStarPortDoc::CStarPortDoc()
3/9 18:17:44.527 << CStarPortDoc::CStarPortDoc()
3/9 18:17:45.198 CMainFrame::OnCreate: Minimizing application to tray.
3/9 18:17:45.198 >> CStarPortAPI::GetEthernetAdapters()
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: Adapter=\DEVICE\{F77917EF-E638-4A95-B361-ED8450825BDE}
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: MAC=00:30:21:08:85:7F
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: Name=DAVICOM 9102-Based PCI Fast Ethernet Adapter
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: Adapter=\DEVICE\{FB991171-7AC7-41F4-9837-E2DB8D150D83}
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: MAC=00:14:D1:3C:1E:C0
3/9 18:17:45.208 CStarPortAPI::GetEthernetAdapters: Name=Realtek RTL8169/8110 Family Gigabit Ethernet NIC
3/9 18:17:45.208 << CStarPortAPI::GetEthernetAdapters()
3/9 18:17:45.208 >> CStarPortView::OnInitialUpdate()
3/9 18:17:45.328 >> CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
3/9 18:17:45.328 >> CStarPortAPI::GetDevices(...)
3/9 18:17:45.328 CStarPortAPI::GetDevices: Calling STARPORT_IOCTL_TARGET_LIST
3/9 18:17:45.328 CStarPortAPI::GetDevices: Output buffer:
3/9 18:17:45.328 CStarPortAPI::GetDevices: NumberOfTargets = 0
3/9 18:17:45.328 << CStarPortAPI::GetDevices(...)
3/9 18:17:45.388 << CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
3/9 18:17:45.448 << CStarPortView::OnInitialUpdate()
3/9 18:18:02.473 CMainFrame::OnTrayStartManagement: Maximizing from tray.
3/9 18:18:08.071 >> CStarPortAPI::GetTargets(dwIPAddress=0x7F000001, DWORD dwPort=3260, listTargets=...)
3/9 18:18:08.071 CStarPortAPI::GetTargets: Calling STARPORT_IOCTL_GET_TARGETS
3/9 18:18:08.071 CStarPortAPI::GetTargets: Input buffer:
3/9 18:18:08.071 CStarPortAPI::GetTargets: ServerAddress = #iscsi:127.0.0.1:3260
3/9 18:18:08.081 CStarPortAPI::GetTargets: Parameter[0] = InitiatorName=iqn.2003-06.com.rocketdivision.starport:dual
3/9 18:18:08.161 CStarPortAPI::GetTargets: Output buffer:
3/9 18:18:08.161 CStarPortAPI::GetTargets: TargetsInfo[0] = TargetName=dual
3/9 18:18:08.161 >> CStarPortAPI::AddTargetToList(target=..., listTargets=...)
3/9 18:18:08.161 CStarPortAPI::AddTargetToList: Target addresses list is empty, adding default IP/Port pair.
3/9 18:18:08.161 << CStarPortAPI::AddTargetToList(target=..., listTargets=...)
3/9 18:18:08.161 CStarPortAPI::GetTargets: Server at IP:0x7F000001, Port:3260 returned the following targets:
3/9 18:18:08.161 CStarPortAPI::GetTargets: TargetName:dual
3/9 18:18:08.161 CStarPortAPI::GetTargets: TargetAddress: IP:0x7F000001, Port:3260
3/9 18:18:08.171 << CStarPortAPI::GetTargets(dwIPAddress=0x7F000001, DWORD dwPort=3260, listTargets=...)
3/9 18:18:10.234 CWPPiSCSITargetSelection::CreateDevice: Trying to add an iSCSI device using TargetName=dual, IP:0x7F000001, Port:3260
3/9 18:18:10.234 >> CStarPortAPI::CStarPortAPI()
3/9 18:18:10.234 >> CStarPortAPI::DriverOpen()
3/9 18:18:10.234 << CStarPortAPI::DriverOpen()
3/9 18:18:10.244 >> CStarPortAPI::DriverVersion(...)
3/9 18:18:10.244 CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
3/9 18:18:10.244 CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
3/9 18:18:10.244 CStarPortAPI::DriverVersion: Input: ApiVersion = 30001
3/9 18:18:10.244 CStarPortAPI::DriverVersion: Output: Version = 20080111, API = 30001, DriverOpenContext = 0, DriverInstance = FFFFFFFF82F58B88
3/9 18:18:10.244 << CStarPortAPI::DriverVersion(...)
3/9 18:18:10.244 CStarPortAPI::CStarPortAPI: StarPort version: 20071025; StarPort driver: API v30001, Build 0x20080111
3/9 18:18:10.244 << CStarPortAPI::CStarPortAPI()
3/9 18:18:10.244 >> CStarPortDoc::CreateiSCSIDevice(IP=0x39AA80, Port=3260, TargetName=dual, Flags=1)
3/9 18:18:10.254 >> CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0x7F000001, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:dual, szTargetName=dual, szAdditionalParameter=, nTargetID=...)
3/9 18:18:10.254 CStarPortAPI::InsertiSCSIDevice: Calling STARPORT_IOCTL_TARGET_MOUNT
3/9 18:18:10.254 CStarPortAPI::InsertiSCSIDevice: Input buffer:
3/9 18:18:10.254 CStarPortAPI::InsertiSCSIDevice: Flags = 1
3/9 18:18:10.254 CStarPortAPI::InsertiSCSIDevice: ServerAddress = #iscsi:127.0.0.1:3260
3/9 18:18:10.264 CStarPortAPI::InsertiSCSIDevice: Parameter[0] = InitiatorName=iqn.2003-06.com.rocketdivision.starport:dual
3/9 18:18:10.264 CStarPortAPI::InsertiSCSIDevice: Parameter[1] = TargetName=dual
3/9 18:18:10.594 CStarPortAPI::InsertiSCSIDevice: Session failed, status == 1326 !
3/9 18:18:10.594 << CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0x7F000001, dwPort=3260, szInitiaotrName=iqn.2003-06.com.rocketdivision.starport:dual, szTargetName=dual, szAdditionalParameter=, nTargetID=...)
3/9 18:18:10.594 << CStarPortDoc::CreateiSCSIDevice(IP=0x39AA80, Port=3260, TargetName=dual, Flags=1)
3/9 18:18:10.594 >> CStarPortAPI::~CStarPortAPI()
3/9 18:18:10.594 << CStarPortAPI::~CStarPortAPI()
3/9 18:18:10.594 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Logon to the server failed.
3/9 18:18:10.604 CWPPiSCSITargetSelection::CreateDevice: Failed to connect to create iSCSI device using TargetName=dual, IP:0x7F000001, Port:3260
3/9 18:18:10.604 CWPPiSCSITargetSelection::CreateDevice: Creation of the iSCSI device failed with all the addresses supplied by the server.
3/9 18:18:10.604 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Creation of the iSCSI device failed with all the addresses
3/9 18:18:15.341 CMainFrame::OnTimer: Refreshing view, received REFRESH_TIMER_ID...
3/9 18:18:15.341 >> CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=0)
3/9 18:18:15.351 >> CStarPortAPI::GetDevices(...)
3/9 18:18:15.351 CStarPortAPI::GetDevices: Calling STARPORT_IOCTL_TARGET_LIST
3/9 18:18:15.351 CStarPortAPI::GetDevices: Output buffer:
3/9 18:18:15.351 CStarPortAPI::GetDevices: NumberOfTargets = 0
3/9 18:18:15.351 << CStarPortAPI::GetDevices(...)
3/9 18:18:15.421 << CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=0)
3/9 18:18:21.029 Found language dll: language id: 0x0409 (English (United States)).
3/9 18:18:30.052 >> CStarPortAPI::GetMaxRAMDiskSize()
3/9 18:18:30.052 CStarPortAPI::GetMaxRAMDiskSize: Calling STARPORT_IOCTL_GET_TARGETS
3/9 18:18:30.052 CStarPortAPI::GetMaxRAMDiskSize: Input buffer:
3/9 18:18:30.052 CStarPortAPI::GetMaxRAMDiskSize: ServerAddress = #ram
3/9 18:18:34.979 CStarPortAPI::GetMaxRAMDiskSize: Output buffer:
3/9 18:18:34.999 CStarPortAPI::GetMaxRAMDiskSize: TargetsInfo[0] = 104
3/9 18:18:34.999 << CStarPortAPI::GetMaxRAMDiskSize()
Sun Mar 09, 2008 8:57 pm
This is StarPort log and we've kindly asked you to send us StarWind one :)
galonga
Mon Mar 10, 2008 6:08 am
you are right: here it goes
3/10 3:43:23.278 b1c Srv: Accepted iSCSI connection from 192.168.0.199:2670. (Id = 0x27)
3/10 3:43:23.278 b1c C[27], FREE: Event - CONNECTED.
3/10 3:43:23.278 b1c C[27], XPT_UP: T3.
3/10 3:43:23.288 528 C[27], XPT_UP: Login request: ISID 0x801234567890, TSIH 0x0000.
3/10 3:43:23.288 528 C[27], XPT_UP: Event - LOGIN.
3/10 3:43:23.288 528 C[27], IN_LOGIN: T4.
3/10 3:43:23.288 528 Params: <<< String param 'InitiatorName': received 'iqn.2003-06.com.rocketdivision.starport:galonga', accepted 'iqn.2003-06.com.rocketdivision.starport:galonga'
3/10 3:43:23.288 528 Params: <<< String param 'TargetName': received 'dual', accepted 'dual'
3/10 3:43:23.288 528 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
3/10 3:43:23.288 528 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
3/10 3:43:23.288 528 Tgt: : *LIMIT* dual: all of 1 allowed sessions are opened!
3/10 3:43:23.288 528 T[1]: *ERROR* Login request: device open failed.
3/10 3:43:23.298 528 C[27], IN_LOGIN: recvData() error (10054)
3/10 3:43:23.298 c60 C[27], IN_LOGIN: Event - LOGIN_REJECT.
3/10 3:43:23.298 c60 C[27], FREE: T7.
apparently it´s because of a maximum connection limit problem? that´s weird considering we never had that problem before with our license (professional). is it possible that when we updated that license was no longer valid?
Anyways, here´s the license data from the help section:
The following connections are present:
localhost:3260
StarWind iSCSI Target v3.5.3 (Build 20080229, Win32)
Active license count: Unlimited
Machine ID: 20EDD8E8
License ID: 2007112801
User name: Al Costa
Type: Professional Server
Organization: Private
aaron (staff)
Mon Mar 10, 2008 7:30 pm
Did you create device with "clustering" option enabled? I mean with 1+ concurrent connection to it allowed? Please send both .cfg and log files to us (via e-mail, they are get truncated in forum). Thanks!
Aaron Korfer
Sales & Support
Rocket Division Software
galonga
Tue Mar 11, 2008 12:15 am
actually that might be the problem, as we were having corruption problems with all the images we created (and despite dataplow´s best efforts!) we may have decided not to allow clustering
if that was the case, can that be changed, or we´d have to create the image all over again?
thanks!
aaron (staff)
Tue Mar 11, 2008 2:20 pm
You cannot access the same target with 1+ initiator at the same time. We're trying to prevent you from crushing the volume.
No, just edit StarWind.cfg setting "Clustered=Yes" for the particular volume.
Aaron Korfer
Sales & Support
galonga
Sun Mar 23, 2008 2:24 pm
Actually I can access the volume with a certain degree of security it from geting corrupted as long as I do it from just ONE initiator
However, if I try a 2nd initiator it says "The file or directory is corrupted and unreadable."
So, only the FIRST initiator gets a readable volume: the SECOND ALWAYS gets garbage.
Is it supposed to work that way, are pushing it too far, or there´s something wrong with the hardware/software?
Thanks folks: you are very supportive :)
aaron (staff)
Sun Mar 23, 2008 2:57 pm
Yes it's supposed to work this way. Bug Redmond guys with the NTFS clusterization update.
Aaron Korfer
Sales & Support
Sun Mar 23, 2008 2:58 pm
-- Thread closed --
Locked
