ESX 3.5 & StartWind 3.5.1?
microfoundry
Thu Dec 13, 2007 6:37 pm
I'm not having any luck reconnecting to my targets after upgrading to ESX 3.5 (GA release). Are there known issues?
TIA,
Terry
Best Regards,
Terry G Phillips
Thu Dec 13, 2007 8:06 pm
No. There are no known issues. Sounds like configuration problem. Please send us StarWind logs to support@rocketdivision.com so we could proceed. Thanks!
microfoundry wrote:I'm not having any luck reconnecting to my targets after upgrading to ESX 3.5 (GA release). Are there known issues?
TIA,
Terry
microfoundry
Thu Dec 13, 2007 9:43 pm
I found the issue. This machine received an in-place upgrade and it seems that the firewall rule for iSCSI was not carried over into the 3.5 config...
Thank you,
Terry
Thu Dec 13, 2007 10:52 pm
Fine :) Thank you for keeping us updated :)
microfoundry wrote:I found the issue. This machine received an in-place upgrade and it seems that the firewall rule for iSCSI was not carried over into the 3.5 config...
Thank you,
Terry
