How to implement the AutoRestore functionality in the DSM
sudhir.kumar3
Fri Oct 26, 2007 7:44 am
Need to implement the AutoRestore functionality in the DSM Code for MPIO with Starwind iSCSI Target. What's logic i can apply?
Host: Microsoft iSCSI Initiator (NIC0 and NIC1)
Target: Starwind iSCSI Target (NICX)
Host I establish the two connections. One connection shows Active Path (NIC0 to NICX) and another connection shows Passive Path (NIC1 to NICX). Now I disable Active Path, Passive path becomes Active Path. Now I enable the disable active path, I found that path remains passive. Now I tried to implement the Restore Function. In Restore Function I am doing SCSI Inquiry. But I not able to perform the Restore Functionality.
My concern issue is that how can I know that Restore Function completed successfully, since I am not getting any value LIKE SP, PORT etc change if I disable the Active Path and Passive Path becoming Active Path. Any help will be appreciated.
Sudhir Kumar
Sudhir Kumar
Fri Oct 26, 2007 8:18 am
Dear Sir, did you get any reply for this request by the e-mail? I just want to make sure we don't have communication problems as I've asked quite a lot of the additional questions based on your initial e-mail :) Thanks!
