Cannot uninstall Startport in Windows 2000
chrisleung
Thu Jun 28, 2007 7:47 pm
Hi, Starport v3.2 installed in Windows 2000 Server SP4 under GSX 3.0 in Windows 2003 server.
Driver dismounted then fire control panel to uninstall Startport.
The Uninstall freese after first progress block show on progress bar either in windows enhance mode or safe mode. Have to call task manager to kill that session in force.
Worst part is the windows 2000 server cannot boot into enhance mode anymore.
Any suggestion?
Regards
Chris
Val (staff)
Sat Jul 07, 2007 9:47 am
chrisleung wrote:Hi, Starport v3.2 installed in Windows 2000 Server SP4 under GSX 3.0 in Windows 2003 server.
Any suggestion?
Regards
Chris
Have you unmounted all of the devices from StarPort before uninstalling?
Valeriy
chrisleung
Sat Jul 07, 2007 5:40 pm
Yes, I did.
Sun Jul 08, 2007 7:57 am
What software (Veritas/Symantec LVM thing, backup, Roxio/Symantec filters) do you have installed? Can you send us complete software list?
Try to delete StarPort.sys from the System32\Drivers folder. Brute force but we've never got anything like this reported before...
chrisleung wrote:Yes, I did.
