Problems with Convert Physical Machine to Proxmox
amiel.atsg
Tue Nov 19, 2024 8:23 am
Hi Everyone,
I am in need of migrating a physical machine to Proxmox. I came across Starwind P2V converter. Below are the steps that I performed in my earlier attempt:
1. Selected P2V
2. Selected "Entire Machine" as the physical data to convert
3. I selected all volumes to be converted including C: drive
4. Selected "Proxmox Server" as the location of the destination image
5. Provided IP/hostname and credentials for the Proxmox Server connection properties.
6. Getting error "the host name or credentials are wrong".
7. Logs shows nothing much:
11/19 16:09:16.921 23a4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
11/19 16:10:31.439 23a4 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Connect to Proxmox host
Proxmox is accessible from the same machine that I am trying to migrate (The same machine where im running Starwind).
Proxmox Authentication is set to Linux PAM standard authentication.
Target machine and Proxmox server resides on 2 different subnets.
Is there any specific port being used by Starwind P2V to initiate connection to Proxmox that needs to be opened? Appreciate any help. Thank you in advance.
Amiel
Tue Nov 19, 2024 8:53 am
Can you please run test-network from the source to proxmox?
jogee77
Thu Nov 28, 2024 3:29 pm
I've got the same problem with 1 VM and 2 Lenovo Windows Clients, all on Windows 10 on current updates
and all of them as full conversions, with 2 different HPE ProLiants running proxmox, 1 current version 8.3.0 and 8.2.2-ish as targets.
It feels like when i either click or press the button to start the conversion,
the click or press goes through the conversion button, so i basically press go and stop at the same time.
The messages Started and Cancelled with the same timestamp seems to confirm that too.
Just not having them sit on top of each other in the GUI would probably make do as a workaround.
Thu Nov 28, 2024 4:16 pm
Can I please see the entire conversion log?
tM@dci
Tue Dec 03, 2024 8:55 pm
I am experiencing the same symptoms, trying to convert from VMware to Proxmox, instant cancel. I tried to send the entire log file, but the anti-spam filter catches it ("Forbidden. Contains contacts. Message seems to be spam. Anti-Spam by CleanTalk."). How can I send my log file?
Tue Dec 03, 2024 9:43 pm
Can you please attach the entire conversion log?
Try attaching it as a file.
tM@dci
Tue Dec 03, 2024 9:49 pm
My bad, I didn't notice the attachment option down there.
V2V_Log-20241127-121131.zip
(2.27 KiB) Downloaded 5512 times
Thu Dec 05, 2024 12:38 pm
I will forward them to the dev team today. Many thanks!
Mon Dec 09, 2024 1:48 pm
tM@dci wrote: ↑
Thanks for your patience.
My colleagues suggested turning off the firewall on the host that is being used for P2V conversion.
acirillo
Fri Dec 20, 2024 10:59 am
i still have this error:
12/20 11:47:39.635 82f0 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Responce is received
12/20 11:47:39.635 82f0 Facility ???ERROR: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Can not create virtual machine: 400
Olso with version 554
any suggestion?
Fri Dec 20, 2024 11:16 am
Welcome to StarWind Forum!
Are you converting the entire VM or the disk?
Please attach the full log to this thread.
acirillo
Fri Dec 20, 2024 11:23 am
yaroslav (staff) wrote: ↑
I tried both way, same result: here's the log
V2V_Log-20241220-122033.zip
(1.33 KiB) Downloaded 5297 times
Fri Dec 20, 2024 9:31 pm
Can you please check firewalls and AV software to be off on the machine?
Mirek
Sun Jan 12, 2025 7:24 pm
The converter worked when I turned off the firewall and Windows Defender. Windows server 2016.
Sun Jan 12, 2025 8:08 pm
Yes it is important that firewall and AV do not clash with the converter.
