Restoring Tapes from Azure Blob Archive tier storage
Mon May 19, 2025 3:06 pm
Sorry for the delay.
I discussed this case internally.
Unfortunately, there is no direct way to cancel cloud upload in the VTL free version. You can change a secret key in Azure,and after several retries, VTL will stop sending tapes to the cloud.
As to optimal part size, this depends a lot on your network throughput. Overall, try increasing the part size in incrementals and see how the upload goes (i.e., trial and error). What I see people do is split to 4 GB pieces, yet it is not necessarily the size you might be looking for. Specifying a larger part size might also result in tape cloud upload failure, as you have seen, as the bandwidth might be too small. Also, please try setting the same part size for S3-compatible, since part size may be read from there as well.
dgbegfb
Thu May 22, 2025 4:57 pm
Delay isn't a prob at all. What's the most important it's a helpfulness. Thank you for the effort.
I've changed the key and after a while after a service restart all replications jobs have stoped with an error "Uploading failed." Everifing loking good at Starwind UI but another issue has raised.
All PS scipts stoped working with un error "Device 'vtl' not found". I can't create new VTL also. Restarting of services doesn't help also.
What next?
Tue May 27, 2025 4:52 pm
Sorry for the delay, we are drafting the plan internally. I will get back to you shortly.
Thu May 29, 2025 3:24 pm
Could you please share the scripts you share and the logs? Please also let me know running which script is causing an issue.
AFAIK, changing the key alone should not cause an issue.
dgbegfb
Tue Jun 03, 2025 10:03 pm
It's quite difficult to share logs and scripts through the forum. Here you are a gdrive link. I sent you pm with the pass.
https://drive.google.com/file/d/1QI65Zr ... sp=sharing
Mon Jun 16, 2025 5:02 pm
Can you please share with me the screenshot of the StarWind management console that shows the device attached to the target, and StarWind.cfg (it is normally at C:\Program Files\StarWind Software\StarWind)?
dgbegfb
Tue Jun 17, 2025 12:35 pm
Tue Jun 17, 2025 12:56 pm
