Mon Dec 15, 2025 2:16 pm
There are vSwitches on your network diagram.
Could you please tell me more about the storage configuration, too? Are there any underlying storage processes running?
Seeing logs from both hosts would be nice.
Mon Dec 15, 2025 3:06 pm
Do you use VSAN as a Windows application? If so, remove the Hyper-V switches (beware of the connectivity drop).
There are storage delays on 02.
12/15 2:48:12.496387 2bc4 IMG: ImageFile_ScsiCompleteRequest: Warning(Time Request EXEC): request(0x0000015925D91220) ssc(0x0000015926AA7240) function(Execute SCSI Command) opCode(0x8A), timeExecRequest = 14750 ms, g_cmdExecTimeWarningLimitInSec = 3 s. Device: 'F:\starwind\datastore03\datastore03.img'
12/15 2:48:12.496414 2bc4 Common: CStarWindStorageDevice::AsyncReadWriteCompleted: Underlying storage request(0x00000159268C8F60, opcode 0x8A) execution time is 14750 ms.
Please reduce replication priority (stop service on the node that undergoes synchronization> edit the header under /headers > set 50 to 5). Please also see what is going on with the storage (hearing more about the configuration will be helpful). Delays like these do not look healthy.
Electrum
Mon Dec 15, 2025 3:54 pm
I've removed the vSwitches and configured the IPs directly on the NICs. I've also lowered the sync priority to 50% as you requested. Datastore03 isn't in use currently, but this isn't something that just affected the disk replicated through that. It is affecting all replicated devices. I'm running a full sync after these changes to see if it makes any difference.
Electrum
Mon Dec 15, 2025 4:49 pm
I did stop it on both. I was going to try to recreate everything again. I assume as long as I don't delete the .img on the host with the correct data I'll be able to import an existing image after I delete all headers and all config on both nodes?
Electrum
Mon Dec 15, 2025 4:55 pm
Yes that is fine. The local disk should be available shortly after if I am importing an existing disk, correct?
Electrum
Mon Dec 15, 2025 5:10 pm
When I add a host in Starwind, I have the option to import an existing device. From there, I can configure the replication to the HA partner. That is what I am referring to. As long as that remains intact, the "data" will remain.
Mon Dec 15, 2025 5:13 pm
There will be a full sync anyway because the bitmap was voided by mutual server stop/initial synchronization. Data can be there, but the service does not "know" about it.
Electrum
Mon Dec 15, 2025 7:14 pm
The disks are all SSDs running in either RAID 1 or RAID 10. The datastores are mirrored on both servers and they consist of:
Datastore 01:
RAID: RAID10
Read Policy: Read Ahead
Write Policy: Write Back
Strip Size: 64K
Consists of:
--6x Samsung 870 @ 1862.5 Gb each
--1x Hot spare
Datastore 02:
RAID: RAID1
Strip Size: 64K
Consists of:
2x INTEL SSDSC2BB01 @ 1118.25 GB each
Datastore 03:
RAID: RAID1
Strip Size: 64K
Consists of:
2x Samsung 860 @ 931 GB each
Wed Dec 17, 2025 7:13 pm
Thanks for your update. 870 and 860 are consumer-grade SSDs.
Update to 20086, and reduce replication priority (stop service on the node that undergoes synchronization> edit the header under /headers > set 50 to 5). Please also see what is going on with the storage (hearing more about the configuration will be helpful). From what I read here, it is still 50%. Storage performance is what is killing the replication now.
Electrum
Thu Dec 18, 2025 12:34 pm
yaroslav (staff) wrote: ↑Wed Dec 17, 2025 7:13 pm
Yes, it is still at 50%. I'll reduce it to 5%. To be clear, this is also occurring on the RAID 1 with enterprise drives. What more details in regards to the configuration can I provide?
