VSAN Free Update
Wed Nov 05, 2025 2:32 pm
Thanks for the log. Does the VM have the IP address from APIPA range?
I am thinking of setting the IP to dhcp for the update. Let me know if that works.
JULDSI
Wed Nov 05, 2025 2:50 pm
I'm not using the apipa network.
The apipa IP is configure on the same card as the management IP.
enpxsxx: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether bc:24:11:36:32:29 brd ff:ff:ff:ff:ff:ff
inet 169.xxx.xxx.xxx/16 brd 169.254.255.255 scope link enpxsxx
valid_lft forever preferred_lft forever
inet 192.xxx.xxx.xxx/24 brd 192.168.xxx.xxx.xxx scope global enpxsxx
It's the same on the witness
I miss a configuration in netplan ??
Wed Nov 05, 2025 3:17 pm
That's interesting.
Looks like there's some misconfiguration, because that's not the way it should be.
Could you please let me know what the host OS is?
Please try resetting the Management IP address.
JULDSI
Wed Nov 05, 2025 3:20 pm
i use the the packaged iso
Welcome to Ubuntu 20.04.1 LTS
So How to reset the management IP ?
Besides i'm in production now :roll: :roll:
Wed Nov 05, 2025 3:49 pm
Management IP should not be used for data/replication.
Try editing the netplan config (removing the 169.x IP address).
JULDSI
Thu Nov 06, 2025 9:46 am
In net plan configuration i have a line :
link-local [IPV4] and i find the same info in /etc/networks link-local 169.254.0.0
I delete the line in the netplan configuration file and it works !!!!!
Thank you so much...
Thu Nov 06, 2025 9:59 am
Thank you for pointing out something interesting in the config files!
