willits
Tue May 27, 2025 3:23 pm
yaroslav (staff) wrote: ↑Tue May 27, 2025 1:02 pm
Thanks for your patience.
I had a word with the dev team. This *.dll should be there (it comes with the installer). Try reinstalling the software.
I reinstalled a number of times. Also tried a different version of the dll from the latest XAMPP, also didn't work.
Tue May 27, 2025 4:42 pm
I've just performed a fresh install of software and the DLL is there
The DLL is attached.
- dll.zip
- (99.81 KiB) Downloaded 1031 times
- Screenshot_116.png (59.41 KiB) Viewed 26443 times
willits
Tue May 27, 2025 4:55 pm
yaroslav (staff) wrote: ↑Tue May 27, 2025 4:42 pm
Yes I see the DLL in my installation as well, but it is not working regardless. Have you tried a conversion with this version? And if so and successful, what OS are you using?
Tue May 27, 2025 4:59 pm
Reportedly, it was successful for Windows 11 (it passed QA somehow).
Please try exporting the VM to OVF or try recreating the VM from individual disks in Proxmox.
willits
Tue May 27, 2025 5:00 pm
yaroslav (staff) wrote: ↑Tue May 27, 2025 4:59 pm
Well this was a test to see if this was a viable way to move a large number of VMs. Apparently not lol
Tue May 27, 2025 5:06 pm
Well, for a large number of VMs, CLI will be ideal.
As of CLI,
Here’s a sample CLI command for converting a virtual machine:
convert in_host_type=win in_host_address="192.168.53.184" in_host_username="" in_host_password="" in_vm_name="VMName1 " out_host_type=win out_host_address="192.168.53.184" out_host_username="" out_host_password="" out_vm_name="OutVMName" out_vm_path="[ds1]" out_vm_os=”Windows”
Key Parameters:
in_vm_name: Specifies the name of the source virtual machine.
out_vm_name: Specifies the name for the destination virtual machine.
out_vm_path: The storage path for the destination virtual machine, formatted according to the target hypervisor:
For Hyper-V, use a directory path (e.g., "E:\VMs").
For ESXi, use a datastore format (e.g., "[ds1]").
For Proxmox, this parameter is not applicable as specific API parameters are used instead.
OS-Specific Parameter
When converting to Hyper-V or ESXi, an additional parameter is required:
out_vm_os: Specifies the operating system of the destination VM. Possible values:
Windows
Linux (default if not specified)
For the conversion of ovirt when it is a destination
out_vm_cluster - spesifies the name of the cluster
out_vm_template - specifies the ovirt template
out_vm_domain - specifies the domain
Conversion to Proxmox Example
Below is an example of converting a VM to Proxmox:
convert in_host_type=win in_host_address="192.168.53.184" in_host_username="" in_host_password="" in_vm_name="CentOS" out_host_type=proxmox out_host_address="192.168.52.127" out_host_username="root" out_host_password="" out_vm_name="CentOSCLI" out_proxmox_storage="vms" out_proxmox_node="sw-v2w-prox" out_proxmox_vmid="1003" out_file_type="ft_raw_kvm"
Additional Parameters for Proxmox:
out_proxmox_storage: Specifies the name of the Proxmox storage location.
out_proxmox_node: Specifies the node name on the Proxmox host.
out_proxmox_vmid: Assigns a unique ID to the new virtual machine. Ensure the ID is valid and not already in use on the Proxmox host.
out_file_type: specifies the output format of the disk files on the proxmox host possible values are ft_raw_kvm, ft_qcow2_v3, ft_qcow2.
By following these guidelines and examples, users can effectively convert virtual machines between supported hypervisors using the V2V CLI.
Examples:
ESX->Proxmox:
convert in_host_type=esx in_host_address="192.168.53.198" in_host_username="root" in_host_password="pass " in_vm_name="CentOS" out_host_type=proxmox out_host_address="192.168.52.127" out_host_username="root" out_host_password="pass" out_vm_name="CentOSProxCLI" out_proxmox_storage="vms" out_proxmox_node="sw-v2w-prox" out_proxmox_vmid="1003"
