physical drive to vmdk
Tue Dec 03, 2024 10:18 am
See them here C:\Program Files\StarWind Software\StarWind V2V Converter\logs.
fpefpe
Thu Dec 05, 2024 12:56 am
Here are the logs
v2v-logs-2024-12-04-12-59-45-305.zip
(12.51 KiB) Downloaded 141 times
fpefpe
Thu Dec 05, 2024 2:28 am
I seem to get it to work – sort of
Converting the 2tb drive (about 800g used) resulted in a VMDK file that was around 800gb — when I went to mount it there were 4 unrelated partitions and the data from physical drive there but not visible. I got the same results creating a VHD file
Next, I used disk2vhd (sysinterals) and since the drive was 2TB it created a VHDX file — when I tried to convert it to a VMDK it generated this error
12/4 11:27:19.962 4a40 Facility ???ERROR: VMwareFile::NewFile: m_VixDiskLib_Create is fail - 16000, One of the parameters supplied is invalid
My next try was to use my backup software to clone / shrink the drive. So now I have a 1tb VHD file. I was able to convert this 800gb VHD file to VMDK
I hope you can get something from the logs to correct this issue – at least being able to process VHDX files
Thanks for the help
Thu Dec 05, 2024 12:41 pm
I will forward them to the dev team today. Many thanks!
As a workaround, you can create a VM with that file and convert it to OVF. Use that OVF to import at the destination.
You can also try https://www.nakivo.com/blog/how-to-conv ... tep-guide/ or use Veeam for now.
Mon Dec 23, 2024 3:37 pm
The dev team requested more logs.
Try P2V conversion and attach the disk to some VM. While converting the disk
1. select disk
2. ESXi host
3. Select any VM you would like to attach the disk to.
4. convert.
If conversion does not work, logs will tell us more about why conversion does not work.
fpefpe
Mon Dec 23, 2024 4:33 pm
thanks for the reply --- I don't have that system setup --- I have vmware workstarion and I tried connecting the physical drive to a vm and it is did not work ---- my laptop is old and probably does not have the power to run that vm setup
Mon Dec 23, 2024 4:43 pm
No worries.
Try disk2VHD conversion and then convert that VHD(X) with V2V Converter.
fpefpe
Mon Dec 23, 2024 4:56 pm
ok -- I can try that
Mon Dec 23, 2024 9:39 pm
Let me know how it works.
