Thu Jan 09, 2025 1:31 pm
Is there any way you can reformat the storage as NTFS (full synchronization will be needed).
Do you use dynamically expanding partition on your underlying storage or is it a simple ReFS volume?
arifurinmoto
Mon Jan 13, 2025 2:28 pm
Thank you for all your help, we finally found the source of our problems!
Initially our Storage Spaces included 6 HDDs on each node then we expand it to 10 HDDs. So pool was set up to have 3 columns and didnt changes to 5 columns after adding new HDDs.
So now we need to rebuild our pools and recreate HApartner on each of node waiting loooong full hash sync
arifurinmoto
Wed Jan 15, 2025 7:45 am
Hi!
We rebuilt storage on one node.
First i recreate lesser device HAImage2 using RemoveHAPartner.ps1 and AddHaPartner.ps1 and its all ok.
Then i recreate bigger device HAImage1 and on second node it become HAImage3.
Such naming isnt so usefull as i expected. Is there any way how i can rename HAImage3 in HAImage1 after full hash sync end?
Wed Jan 15, 2025 1:42 pm
There's no straightforward way as it is needed to modify the config files on both nodes.
The easiest way will be just to leave it as is.
