HA device timeout error
Thu Feb 08, 2024 11:18 am
MPIO can be the Least Queue Depth for witnesse HA too.
Are other devices (i.e., data), also connected from both servers?
bertram
Sat Feb 10, 2024 8:25 am
logitech wrote: 2. StarWind VSAN 8.0.15260 installed
an old version installed, we will plan for the upgrade soon.
What version do you running? I can remember we had the same issue after installing Version V8 (build 14947) but I can not say from which version. The seperate active/active cluster was running fine after the update for ~2 weeks but out of nothing your mentioned issues appeared. After updating to the successor Version V8 (build 15020) the problem disappeared. I assume a bug was fixed with this version when I read the notes: "Synchronous Replication - Fixed spurious replication failure."
I hope you can solve your problem.
Regards
betram
logitech
Mon Feb 12, 2024 7:10 pm
We updated the policy settings for all connections from virtual hosts to the storage nodes to "Least Queue Depth" .
Do we need to update the policy settings from Storage Node A to Storage Node B too?
Mon Feb 12, 2024 9:33 pm
You need to update for both nodes.
logitech
Tue Feb 13, 2024 9:54 am
I already updated the connection policy on vh01 and vh02. I don't see any iSCSI connection between storage01 and storage02 to update the policy settings.
what do you mean by both nodes? the hypervisor or storage?
Tue Feb 13, 2024 11:19 am
I mean it for hypervisor. It has to be on all hypervisor nodes for all ha devices.
logitech
Tue Feb 13, 2024 1:13 pm
done, does it require any restart to take effect?
Tue Feb 13, 2024 1:47 pm
Nope.
Wed Feb 14, 2024 8:50 pm
Updates are installed manually.
See https://knowledgebase.starwindsoftware. ... d-version/. This procedure describes how to avoid downtime.
For CVM, press the Gear button at the top -> Update. The general prerequisites: check storage connectivity, check HA devices synchronization, etc. are the same.
logitech
Sat Feb 17, 2024 6:18 pm
What is the difference between MCS policy and MPIO policy? both should be Least Queue Depth.
Sat Feb 17, 2024 9:44 pm
We recommend the Least Queue Depth as it grants the best performance.
logitech
Sun Feb 18, 2024 8:15 am
should we apply Least Queue Depth policy on MPIO and MCS policy settings?
Mon Feb 19, 2024 4:03 am
Could you please let me know what MCS is?
logitech
Mon Feb 19, 2024 6:54 pm
Mon Feb 19, 2024 8:21 pm
Thank ypu.
For one path it does not matter for multiple paths please use Least Queue Depth.
