Poor performance
webdude
Sat Jun 11, 2022 1:49 pm
I believe this to be related to iSCSI itself. Try at least 5 "local" and 3 "partner" iSCSI sessions. Should improve the performance.
how to configure multiple iSCSI sessions? can you please elaborate? does this work with 1 NIC 25Gbps dedicated for HB +iSCSI? I have two nodes only.
My configuration:
HPE DL380 Gen10 with Dual Gold 6226R, 512GB memory, Full flash-based storage Kingston DC500M with RAID50, NIC: HPE 631SFP28 25Gbps and HPE 535T 10Gbps.
I installed Windows server 2022 and StarWind trial, done all the necessary configs so far.
I'm testing the performance using diskpd and the results are not up to the expectations.
Results attached!
Diskpd results.rar
diskpd results as per the starwind benchmark link
(5.78 KiB) Downloaded 1143 times
Sat Jun 11, 2022 4:48 pm
May I wonder what the underlying storage results are?
Try fewer sessions: 3 local and 2 partner.
Finally, if the trial key is still active, please contact support@starwind.com. Use this thread and 711573 as your references.
webdude
Mon Jun 13, 2022 7:41 am
I will share the results today or maxi tomorrow.
Re. fewer sessions: 3 local and 2 partner. can you please elaborate? how to configure multi-sessions?
Mon Jun 13, 2022 9:14 am
Please use Microsoft iSCSI initiator. There, you can configure multiple iSCSI sessions as described here https://www.starwindsoftware.com/resour ... 0e77312268
