Synchronizing stucks at 0%
massimo.favretto
Mon Jun 07, 2021 3:24 pm
VSA-01.zip
File for VSA-01
(9 KiB) Downloaded 787 times
massimo.favretto
VSA-02.zip
File for VSA-02
(8.99 KiB) Downloaded 817 times
VSA-02.zip
File for VSA-02
Mon Jun 07, 2021 4:18 pm
I noticed that you did not use the script I shared. The script I mentioned earlier has 3 interfaces: 2 heartbeat (iSCSI and Management)+Sync.
Your files have only one heartbeat link. Please consider redoing the HA devices the way described here https://forums.starwindsoftware.com/vie ... p+3#p31505.
Also, please be aware of the StarWind VSAN system requirements https://www.starwindsoftware.com/system-requirements.
How to replace the .cfgs. Stop StarWindService on both sides -> Copy the existing config files -> delete them in /StarWind -> Bring the new config files (rename them removing the indexes) -> Start the service on both nodes.
cfgs.zip
(15.38 KiB) Downloaded 771 times
massimo.favretto
Mon Jun 07, 2021 7:33 pm
After applying the cfg files I obtain this error:
massimo.favretto
Mon Jun 07, 2021 7:42 pm
If I try to manually sync device with the SyncHaDevice.ps1 script I obtain this error:
Mon Jun 07, 2021 8:53 pm
Hi, log the case with us by sending an email to support@starwind.com. Use this thread and 521132 as the reference.
massimo.favretto
Tue Jun 08, 2021 7:08 am
Modifying my script, and simply adding the IP of management as you suggest I got it functioning.
$syncInterface="#p2=192.168.1.21:3260" -f $addr2,
$hbInterface="#p2=192.168.2.21:3260", 192.168.0.41:3260" -f $addr2,
$syncInterface2="#p1=192.168.1.11:3260" -f $addr,
$hbInterface2="#p1=192.168.2.11:3260", 192.168.0.31:3260" -f $addr,
massimo.favretto
Tue Jun 08, 2021 7:14 am
I would to thank you for the time spent in resolve my problem
Tue Jun 08, 2021 7:39 am
Glad to know that it finally works :)
Do not hesitate to contact me if assistance is required.
ballzop
Thu Jul 01, 2021 12:01 pm
Were you able to connect the targets to ESXi? tomzpot mdro.fun/mobdro/
Thu Jul 01, 2021 1:50 pm
The targets should be available once you rescan the storage and adapter.
