PowerShell - StarWindX bug - HA device create
Olgir
Mon Apr 09, 2018 3:34 pm
Hello, we have the same issue here. Any hope to fix it? Maybe if I rename HA device, it will work? But how can I rename it from powershell? Couldn't find tools in StarWindX to do so.
Our trial is already over and now we can't use StarWind anymore because of this problem :(.
Tue Apr 10, 2018 8:48 am
Olgir,
It is nothing as simple as renaming the HA device. As I have previously outlined, this issue will be fixed in the new build expected to arrive a bit later.
vladimir@ngsoft.com
Sun May 06, 2018 9:25 am
Thank you, Boris, it actually was solved in the v8_build_12146 version.
Olgir, you can upgrade it or use the same workaround I used - install StartWindX library of older version (v8_build_1145) on another computer and run PowerShell scripts from there to add disks.
Mon May 07, 2018 10:14 am
Indeed, this is a possible workaround.
