I didn't get a chance to add this information until now but last night I verified that if I passthrough the RAID adapter to the SAN VM and present LUNS back to the host, everything works great. Prior to that, I tried removing Starwind and installing the Microsoft iSCSI target and I saw file copies freeze in the same fashion as Starwind. I figured that must be due to an LSI/PVSCSI driver issue or contention. Either are beyond my ability to troubleshoot.
The advantage I found about passing the raid adapter through to the VM is now I can use the Megaraid Storage Manager application to manage and perform maintenance and monitoring of the array. In addition performance may be better as I'm serving LUNS directly on the file system instead of adding a layer of VMFS, than NTFS in order to present VMFS to ESXi.
Hope this helps. Maybe this will give another configuration option for Starwind...
Chris
