Mon Mar 30, 2015 9:56 pm
If I use the iscsicli command line tool, I am able to issue a “iscsicli RefreshTargetPortal 127.0.0.1 3260” that successfully refreshes the targets list without loss of outside networking.
you can then use the gui to see the targets, and connect, or continue to use the command line.
I determined through testing this problem exists prior to installing starwind, and could be the specific windows iso I'm using. I'll post another update, when I nail down exactly what causes the issue, however with the workaround, issue is less critical.
