horrible slow connection to ESX
deiruch
Sun Dec 04, 2011 10:14 pm
Have you tried attaching the disks directly, not through the PERC 5/iR? I once set up some Dell servers that had disastrous performance. As soon as I used dirt-cheap SATA disks, connected to the board (the mainboard had connectors too), the problem disappeared. I saw the same problems you describe here (except that I wasn't running StarWind on those servers).
ghost
Mon Jan 23, 2012 5:07 pm
In the mean time i switched NICs (now onboard iSCSI <-> PCI-X or PCIe i forgot, normal LAN), still the same.
At the moment i cannot bypass the PERC controller, because Windows is installed on the same disks (Windows no software RAID1 for OS). Another 2 disks i also cannot install because there is no place with "big" DAT drive:
http://www.disasterzone.net/blog/upload ... inside.png
I already discovered that the controller is a lot faster when write cache is enabled, which is no default. With that i had even lower speeds but now its maybe a different problem.
But what i will also try is to directly connect the NICs without switch
What it is really stupid is, the problem takes some days to appear
@deiruch
were this really SAS disks with problem? Once i had big speed troubles with WD SATA RAID disks on a HP SAS controller. Now i have also SATA disks.
Mon Jan 23, 2012 11:32 pm
Try isolating your issue removing (replacing) components one-by-one.
1) NICs
2) Switch
3) Controller
ghost wrote:In the mean time i switched NICs (now onboard iSCSI <-> PCI-X or PCIe i forgot, normal LAN), still the same.
@deiruch
deiruch
Wed Jan 25, 2012 9:41 pm
ghost wrote:@deiruch
Sorry, can't remember, was some time ago. Can't you connect a single SATA disk, just for testing?
Thu Jan 26, 2012 12:53 am
Better SSD...
danisoto
Fri Jan 27, 2012 8:51 am
ghost wrote:I only have windows clients and ESX, so i ran iperf between windows vm and windows machine with starwind. Got around 550mbit/s. But how this will test iSCSI network?
To check iSCSI with VSphere, try "iperf" for ESXi:
http://www.vm-help.com/forum/viewtopic. ... erf#p11541
Best check it with the real hosts (ESXi to SAN) using the real path (if you have multiple paths).
Regards!
Mon Jan 30, 2012 10:32 am
Thank you for suggestion! Great tool to check raw TCP performance.
Regards!
danisoto
Mon Jan 30, 2012 11:18 am
anton (staff) wrote:Thank you for suggestion! Great tool to check raw TCP performance.
You welcome!
Mon Jan 30, 2012 3:37 pm
ghost, we will wait for your update then.
ghost
Wed Mar 07, 2012 5:44 pm
reboot every week seems to fix it, probably problem with cache though
absolutely legit :mrgreen:
Fri Mar 09, 2012 10:32 am
Well, I`m glad that everything finished good! :D
