Starwind Thin Provisioning
Thu Dec 29, 2011 9:04 pm
There's no such thing as "simple thin provisioning". You also get snapshots with it (in case of near-CDP) and deduplication. Dedupe is not in beta BTW. We'll consider opportunity to implement "TP only" volumes however.
kevin@nextvault.com wrote:Since Dedupe appears to still be beta, I'm confused how to setup Thin provisioning in production.
I see it available under the CDP setting, but don't see how to just setup a simple, thin provisioned image. I don't need any special features on it, just thin provision so it grows as it needs to, like you have described and we have seen in the dedupe mode.
kevin@nextvault.com
Thu Dec 29, 2011 9:47 pm
Thanks for the prompt feedback.
I will give the CDP/TP version another try.
On my server which I just installed Starwind 2 weeks ago, when selecting Advanced Virtual, the next screen shows Deduplicated Disk Device, along with other options. Next to Deduplicated Disk Device is a big star. Looking at the bottom of the screen the star indicates "Items marked with (star) are experimental. Use at your own risk"
So I am confused about this statement and yours. Please advise. Thanks
Thu Dec 29, 2011 9:52 pm
"Experimental" does not mean "beta". VMware has half of their features marked "experimental".
Also with release 5.8 we'll remove all "stars".
kevin@nextvault.com wrote:Thanks for the prompt feedback.
