You could try this method if you need it.galonga wrote:well if you say it's an obsolete method we won't use it.
actually, we deleted the ibv image and created an img one, only to remember we were also having problems formatting this kind of volume
that problem happened with the K6 servers we told you about: we tried with a newer machine (athlon) and worked ok
that's why I think this technology might not be very suitable for old harware (?)
Do you mean more than one iSCSI client mounts the same iSCSI target and write data to it?galonga wrote:no more than 3anton (staff) wrote:How many concurrent connections do you have active to the same volume at any moment of time?
NTFS changes some information on the disk ever it is only read.galonga wrote:actually no one is writing data: they only read it
that because the data involved is just images, asp files, etc. just web stuff that is just READ, and not altered any way
that's why I find this weird...
If the image is rarely changed, just prepare it and create a readonly target for your clients.galonga wrote:the readonly mark is a good idea, but should we need to change an ASP file or insert a new image how would we do it?
A third-party SAN manager should be use to control shared access to the iSCSI device.galonga wrote:but what you said worries me, for that means that it can't be used for a clustered database for example?
galonga wrote:do you think manageengine's opstor 5 is a good option too?
