Issue QuickFormating iSCSI disks
sporky
Sun Mar 18, 2007 10:38 am
I'm currently running runninga 2 node Windows Server 2003 R2 Ent SP2 Cluster (this also happen when I was running SP1) with around 7 StarWind iSCSI disks running on both nodes. I'm currently using the Microsoft iSCSI initiator 2.03
The first 5 disks formated without issue but the 6th and 7th disks take around 30mins to 1Hour to quickformat and generate the follow eventlog errors every few seconds. The hex included with the the event logs also a different disk fro the one being formated.
Event Type: Information
Event Source: iScsiPrt
Event Category: None
Event ID: 34
Date: 18/03/2007
Time: 10:15:23
User: N/A
Computer: CN-SVR-DC-01
Description:
A connection to the target was lost, but Initiator successfully reconnected to the target. Dump data contains the target name.
For more information, see Help and Support Center at [ ... ]
Data:
0000: 00 00 42 00 01 00 9e 00 ..B...ž.
0008: 00 00 00 00 22 00 00 40 ...."..@
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 69 00 71 00 6e 00 2d 00 i.q.n.-.
0030: 32 00 30 00 30 00 37 00 2.0.0.7.
0038: 2d 00 30 00 31 00 2e 00 -.0.1...
0040: 75 00 6b 00 2e 00 63 00 u.k...c.
0048: 6f 00 2e 00 63 00 6c 00 o...c.l.
0050: 61 00 72 00 6b 00 65 00 a.r.k.e.
0058: 73 00 6e 00 65 00 74 00 s.n.e.t.
0060: 3a 00 64 00 68 00 63 00 :.d.h.c.
0068: 70 00 p.
Event Type: Error
Event ID: 49
Date: 18/03/2007
Time: 10:15:23
User: N/A
Description:
Target failed to respond in time to a Task Management request.
Data:
0000: 00 00 01 00 01 00 5e 00 ......^.
0008: 00 00 00 00 31 00 00 c0 ....1..À
0028: 07 .
Event Type: Error
Event ID: 23
Date: 18/03/2007
Time: 10:15:23
User: N/A
Description:
Target sent an invalid iSCSI PDU. Dump data contains the entire iSCSI header.
Data:
0000: 00 00 30 00 01 00 8a 00 ..0...Š.
0008: 00 00 00 00 17 00 00 c0 .......À
0028: 22 00 05 00 00 00 00 00 ".......
0030: 00 00 00 00 00 00 00 00 ........
0038: 00 00 09 b6 00 00 00 00 ...¶....
0040: 00 00 00 17 00 00 09 b6 .......¶
0048: 00 00 09 f5 00 00 00 00 ...õ....
0050: 00 00 00 00 00 00 00 00 ........
Event Type: Error
Event ID: 39
Date: 18/03/2007
Time: 10:15:23
User: N/A
Description:
Initiator sent a task management command to reset the target. The target name is given in the dump data.
Data:
0008: 00 00 00 00 27 00 00 c0 ....'..À
0068: 70 00 p.
Event Type: Error
Event Source: ClusDisk
Event ID: 1209
Date: 18/03/2007
Time: 10:15:23
User: N/A
Description:
Cluster service is requesting a bus reset for device \Device\ClusDisk0.
Data:
0000: 12 00 00 00 01 00 5a 00 ......Z.
0008: 00 00 00 00 b9 04 00 00 ....¹...
0010: 43 6c 6e 20 00 00 00 00 Cln ....
sporky
Val (staff)
Mon Mar 19, 2007 12:40 pm
Which type of iSCSI targets do you use?
Could you send the corresponding log files from the StarWind Service to my email?
Valeriy
sporky
Mon Mar 19, 2007 2:45 pm
I'm running StarWind 3.2.1 (build 20061130) and the disks are "ImageFile"'s which have been NTFS formated.
I will email the logs in this evening.
Mat
Val (staff)
Mon Mar 19, 2007 3:09 pm
sporky wrote:I'm running StarWind 3.2.1 (build 20061130) and the disks are "ImageFile"'s which have been NTFS formated.
Mat
Mat,
Thanks.
Waiting for the logs...
Valeriy
