Wed Nov 01, 2006 3:23 pm
Here is a snippet of the tail end of a 350meg log file
10/26 20:12:01 a84 Params: <<< String param 'TargetName': received 'virlp5001.prertdom.com.spti:disk.physicaldrive30', accepted 'virlp5001.prertdom.com.spti:disk.physicaldrive30'
10/26 20:12:01 238 Srv: Accepted connection from 10.160.218.77:2805. id assigned - 186674
10/26 20:12:01 a84 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
10/26 20:12:01 a84 S: virlp5001.prertdom.com.spti:disk.physicaldrive30: 1 session(s) are opened, 0 more allowed.
10/26 20:12:01 a84 SPTI: '\\.\PhysicalDrive30': sessions: 1.
10/26 20:12:01 a84 SPTI: '\\.\PhysicalDrive30': Test failed, the device cannot execute SCSI command. (SCSI status 0x0).
10/26 20:12:01 a84 SPTI: '\\.\PhysicalDrive30': openDevice() failed!
10/26 20:12:01 a84 S[0x2ea41]: *ERROR* can't register Session. The device '\\.\PhysicalDrive30' may be owned by a local process!
10/26 20:12:01 a84 S: virlp5001.prertdom.com.spti:disk.physicaldrive30: 0 session(s) are opened, 1 more allowed.
10/26 20:12:01 a84 T[0x4f83]: *ERROR* Login request: device open failed.
10/26 20:12:01 238 C[0x2d932], FREE: Event - CONNECTED.
10/26 20:12:01 238 C[0x2d932], XPT_UP: T3.
10/26 20:12:01 5f0 C[0x2d931], IN_LOGIN: Event - LOGIN_REJECT.
10/26 20:12:01 5f0 C[0x2d931], FREE: T7.
10/26 20:12:01 17d4 C[0x2d932], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
10/26 20:12:01 17d4 C[0x2d932], XPT_UP: Event - LOGIN.
10/26 20:12:01 17d4 C[0x2d932], IN_LOGIN: T4.
10/26 20:12:01 17d4 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com', accepted 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com'
10/26 20:12:01 17d4 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
10/26 20:12:01 17d4 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
10/26 20:12:01 17d4 T[0x1]: Anonymous connection allowed.
10/26 20:12:01 17d4 Params: >>> AuthMethod=None.
10/26 20:12:01 13c8 T[0x1]: The end of stage 0, next stage is 1.
10/26 20:12:01 a84 C[0x2d931], FREE: recvData() error (10058)
10/26 20:12:01 17d4 Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
10/26 20:12:01 17d4 Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
10/26 20:12:01 17d4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
10/26 20:12:01 17d4 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
10/26 20:12:01 17d4 Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
10/26 20:12:01 17d4 Params: >>> HeaderDigest=None.
10/26 20:12:01 17d4 Params: >>> DataDigest=None.
10/26 20:12:01 17d4 Params: >>> InitialR2T=No.
10/26 20:12:01 17d4 Params: >>> ImmediateData=Yes.
10/26 20:12:01 17d4 Params: >>> MaxRecvDataSegmentLength=65536.
10/26 20:12:01 17d4 Params: >>> MaxBurstLength=262144.
10/26 20:12:01 17d4 Params: >>> FirstBurstLength=65536.
10/26 20:12:01 17d4 Params: >>> DefaultTime2Wait=2.
10/26 20:12:01 17d4 Params: >>> DefaultTime2Retain=20.
10/26 20:12:01 17d4 Params: >>> MaxOutstandingR2T=1.
10/26 20:12:01 17d4 Params: >>> DataPDUInOrder=Yes.
10/26 20:12:01 17d4 Params: >>> DataSequenceInOrder=Yes.
10/26 20:12:01 13c8 T[0x1]: The end of stage 1, next stage is 3.
10/26 20:12:01 13c8 C[0x2d932], IN_LOGIN: Event - LOGIN_ACCEPT.
10/26 20:12:01 13c8 C[0x2d932], LOGGED_IN: T5.
10/26 20:12:01 13c8 C[0x2d932], LOGGED_IN: Event - LOGOUT.
10/26 20:12:01 13c8 C[0x2d932], IN_LOGOUT: T9/10.
10/26 20:12:01 bf4 C[0x2d932], IN_LOGOUT: Event - LOGOUT_ACCEPT.
10/26 20:12:01 bf4 C[0x2d932], FREE: T13.
10/26 20:12:01 238 Srv: accept() failed: An operation on a socket could not be performed because the system lacked sufficient buffer space or because a queue was full. (code: 10055).
10/26 20:12:01 14dc conf: Stop listening to control connections.
10/26 20:12:01 238 Srv: Timeout 10 second(s)...
10/26 20:12:11 238 Srv: Wait for shutdown failed. Terminating....
