how do I attach ?Alex (staff) wrote:Hi,
Please, change LogLevel to 3 in the configuration file (StarWind.conf), restart StarWindService and try to reproduce your ploblem. Then send me, please, the log file you get and your StarWind.conf.
tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
It keeps failing to bring the drives online.
Cluster Machine windows 2003 Adv Server
Starwind Target windows 2000 server in same domain
I have set up out of the box with two 3GB drives in a 8gb primary NTFS partition.
Where am I going wrong ?
It seems you already found my e-mail.tykes wrote:how do I attach ?
Try to use MS iSCSI Initiator instead of StarPort in the same situation. Just to isolate the problem.tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
Hi Tykes,tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
Thank I tried the MS initiator whick had the same issueAlex (staff) wrote:Try to use MS iSCSI Initiator instead of StarPort in the same situation. Just to isolate the problem.tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
Not quite the file starwind sw is on the windows 200 machine and I am trying to build the first node of a cluster.valery (staff) wrote:Hi Tykes,tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
If I got it right way you are trying to build your cluster using the 2 machines (Win2003 Server and Win2000 Server), am I right?
BTW which iSCSI initiator are you using? MS one or our StarPort or something else?
Do you mean your remote dynamic disks stay marked 'Offline' after a system reboot?
This is an iSCSI initiator's issue and we know about it.
We'are planning to implement auto onlining of dynamic disks in the next StarPort Initiator release...
IIRC MS iSCSI Initiator also has such an ability. Please look at their docs for more details...
[/b]
Anonymous wrote:valery (staff) wrote:tykes wrote:
Do you have a procedure to build a cluster solution using Starwind as the SAN source which is known to work as I can start from of clean slate if need be.
Anonymous wrote:Not quite the file starwind sw is on the windows 200 machine and I am trying to build the first node of a cluster.valery (staff) wrote:Hi Tykes,tykes wrote:I am trying to build a MS Cluster and cannot get past he first node creation.
[/b]
I have tried the ms initiatior 1.05
the windows 2000 box has 1 drive which is a basic ( not dynamic disk) with three partitions. 1 Primary 1, 1 secondary with two partitions. I am mounting the cluster drive on a directory on the first logical drive on the secondary partition and have tried NTFS and FAT32 formatiing
