I'm using Starwind 2.6.4 to connect a guest on a MS Virtual Server that is part of a cluster. When I try to fail the cluster on to the VGS the Starwind service stops and the following text is in the log file. I know there is a new version out and it is under evaluation at the moment. Upgrading this box will be politically difficult at the moment. I am a new Starwind user so please be gentle with me
7/28 10:38:39 17fc Srv: Accepted connection from 10.160.218.77:3003. id assigned - 4660
7/28 10:38:39 17fc C[0x1234], FREE: Event - CONNECTED.
7/28 10:38:39 17fc C[0x1234], XPT_UP: T3.
7/28 10:38:39 17b0 C[0x1234], XPT_UP: Login request: ISID 0x400001370001, TSIH 0x0000.
7/28 10:38:39 17b0 C[0x1234], XPT_UP: Event - LOGIN.
7/28 10:38:39 17b0 C[0x1234], IN_LOGIN: T4.
7/28 10:38:39 17b0 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com', accepted 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com'
7/28 10:38:39 17b0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/28 10:38:39 17b0 Params: <<< String param 'TargetName': received 'virlp5001.prertdom.com.spti:disk.physicaldrive31', accepted 'virlp5001.prertdom.com.spti:disk.physicaldrive31'
7/28 10:38:39 17b0 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/28 10:38:39 17b0 Params: Update OFMarkInt according to the value of OFMarker.
7/28 10:38:39 17b0 Params: Update IFMarkInt according to the value of IFMarker.
7/28 10:38:39 17fc Srv: Accepted connection from 10.160.218.77:3004. id assigned - 4661
7/28 10:38:39 17b0 S: virlp5001.prertdom.com.spti:disk.physicaldrive31: 1 session(s) are opened, 0 more allowed.
7/28 10:38:39 17b0 SPTI: '\\.\PhysicalDrive31': Test failed, the device cannot execute SCSI command. Status 0, SCSI status 0x0.
7/28 10:38:39 17b0 SPTI: '\\.\PhysicalDrive31': openDevice() failed!
7/28 10:38:39 17b0 S[0x2344]: *ERROR* can't register Session. The device '\\.\PhysicalDrive31' may be owned by a local process!
7/28 10:38:39 17b0 T[0x7e]: *ERROR* Login request: device open failed.
7/28 10:38:39 17fc C[0x1235], FREE: Event - CONNECTED.
7/28 10:38:39 17fc C[0x1235], XPT_UP: T3.
7/28 10:38:39 1540 C[0x1234], IN_LOGIN: Event - LOGIN_REJECT.
7/28 10:38:39 1540 C[0x1234], FREE: T7.
7/28 10:38:39 d48 C[0x1235], XPT_UP: Login request: ISID 0x400001370001, TSIH 0x0000.
7/28 10:38:39 17fc Srv: Accepted connection from 10.160.218.77:3005. id assigned - 4662
7/28 10:38:39 17fc C[0x1236], FREE: Event - CONNECTED.
7/28 10:38:39 d48 C[0x1235], XPT_UP: Event - LOGIN.
7/28 10:38:39 17fc C[0x1236], XPT_UP: T3.
7/28 10:38:39 d48 C[0x1235], IN_LOGIN: T4.
7/28 10:38:39 d48 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com', accepted 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com'
7/28 10:38:39 d48 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/28 10:38:39 d48 Params: <<< String param 'TargetName': received 'virlp5001.prertdom.com.spti:disk.physicaldrive15', accepted 'virlp5001.prertdom.com.spti:disk.physicaldrive15'
7/28 10:38:39 d48 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/28 10:38:39 d48 Params: Update OFMarkInt according to the value of OFMarker.
7/28 10:38:39 d48 Params: Update IFMarkInt according to the value of IFMarker.
7/28 10:38:39 1220 C[0x1236], XPT_UP: Login request: ISID 0x400001370001, TSIH 0x0000.
7/28 10:38:39 1220 C[0x1236], XPT_UP: Event - LOGIN.
7/28 10:38:39 1220 C[0x1236], IN_LOGIN: T4.
7/28 10:38:39 1220 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com', accepted 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com'
7/28 10:38:39 1220 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/28 10:38:39 1220 Params: <<< String param 'TargetName': received 'virlp5001.prertdom.com.spti:disk.physicaldrive30', accepted 'virlp5001.prertdom.com.spti:disk.physicaldrive30'
7/28 10:38:39 1220 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/28 10:38:39 1220 Params: Update OFMarkInt according to the value of OFMarker.
7/28 10:38:39 1220 Params: Update IFMarkInt according to the value of IFMarker.
7/28 10:38:39 17b0 C[0x1234], FREE: recvData() error (10058)
7/28 10:38:39 17fc Srv: Accepted connection from 10.160.218.77:3006. id assigned - 4663
7/28 10:38:39 d48 S: virlp5001.prertdom.com.spti:disk.physicaldrive15: 1 session(s) are opened, 0 more allowed.
7/28 10:38:39 d48 SPTI: '\\.\PhysicalDrive15': Test failed, the device cannot execute SCSI command. Status 0, SCSI status 0x0.
7/28 10:38:39 d48 SPTI: '\\.\PhysicalDrive15': openDevice() failed!
7/28 10:38:39 d48 S[0x2345]: *ERROR* can't register Session. The device '\\.\PhysicalDrive15' may be owned by a local process!
7/28 10:38:39 d48 T[0x79]: *ERROR* Login request: device open failed.
7/28 10:38:39 1220 S: virlp5001.prertdom.com.spti:disk.physicaldrive30: 1 session(s) are opened, 0 more allowed.
7/28 10:38:39 6fc C[0x1235], IN_LOGIN: Event - LOGIN_REJECT.
7/28 10:38:39 6fc C[0x1235], FREE: T7.
7/28 10:38:39 1220 SPTI: '\\.\PhysicalDrive30': Test failed, the device cannot execute SCSI command. Status 0, SCSI status 0x0.
7/28 10:38:39 1220 SPTI: '\\.\PhysicalDrive30': openDevice() failed!
7/28 10:38:39 1220 S[0x2346]: *ERROR* can't register Session. The device '\\.\PhysicalDrive30' may be owned by a local process!
7/28 10:38:39 1220 T[0x7e]: *ERROR* Login request: device open failed.
7/28 10:38:39 17fc C[0x1237], FREE: Event - CONNECTED.
7/28 10:38:39 17fc C[0x1237], XPT_UP: T3.
7/28 10:38:39 730 C[0x1236], IN_LOGIN: Event - LOGIN_REJECT.
7/28 10:38:39 730 C[0x1236], FREE: T7.
7/28 10:38:39 918 C[0x1237], XPT_UP: Login request: ISID 0x400001370001, TSIH 0x0000.
7/28 10:38:39 17fc Srv: Accepted connection from 10.160.218.77:3007. id assigned - 4664
7/28 10:38:39 17fc debug: assertion failed: d:\cvs\starwind\service\server\session.cpp:80 (m_exec.isOk())
7/28 10:38:39 17fc C[0x1238], FREE: Event - CONNECTED.
7/28 10:38:39 17fc C[0x1238], XPT_UP: T3.
7/28 10:38:39 918 C[0x1237], XPT_UP: Event - LOGIN.
7/28 10:38:39 918 C[0x1237], IN_LOGIN: T4.
7/28 10:38:39 918 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com', accepted 'iqn.1991-05.com.microsoft:dbslp5501.prertdom.com'
7/28 10:38:39 918 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/28 10:38:39 918 Params: <<< String param 'TargetName': received 'virlp5001.prertdom.com.spti:disk.physicaldrive33', accepted 'virlp5001.prertdom.com.spti:disk.physicaldrive33'
7/28 10:38:39 918 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/28 10:38:39 918 Params: Update OFMarkInt according to the value of OFMarker.
7/28 10:38:39 918 Params: Update IFMarkInt according to the value of IFMarker.
7/28 10:38:39 d48 C[0x1235], FREE: recvData() error (10058)
7/28 10:38:39 484 C[0x1238], XPT_UP: *ERROR* 'send' thread: WaitForMultipleObjects failed: The handle is invalid. (code: 6).
7/28 10:38:39 484 C[0x1238], XPT_UP: *ERROR* 'recv' thread (1714): failed to close the socket gracefully.
7/28 10:38:39 484 C[0x1238], XPT_UP: *ERROR* 'recv' thread: waiting failed, waitResult 0xffffffff. The handle is invalid. (code: 6).
7/28 10:38:39 484 debug: Release Semaphore called for invalid handle!
7/28 10:38:39 69c S[0x2348]: 'exec' thread: WaitForSingleObject returned -1: The handle is invalid. (code: 6).
7/28 10:38:39 69c debug: Release Semaphore called for invalid handle!
7/28 10:38:39 1220 C[0x1236], FREE: recvData() error (10058)
7/28 10:38:39 918 S: virlp5001.prertdom.com.spti:disk.physicaldrive33: 1 session(s) are opened, 0 more allowed.
7/28 10:38:39 69c debug: The program encountered a serious error and may be closed. Crash dump will be created.
7/28 10:38:39 69c debug: Please, send this log file and the crash dump to 'support@starwind.com'.
7/28 10:38:39 918 SPTI: '\\.\PhysicalDrive33': Test failed, the device cannot execute SCSI command. Status 0, SCSI status 0x0.
7/28 10:38:39 918 SPTI: '\\.\PhysicalDrive33': openDevice() failed!
7/28 10:38:39 918 S[0x2347]: *ERROR* can't register Session. The device '\\.\PhysicalDrive33' may be owned by a local process!
7/28 10:38:39 918 T[0x7e]: *ERROR* Login request: device open failed.
7/28 10:38:39 1544 C[0x1237], IN_LOGIN: Event - LOGIN_REJECT.
7/28 10:38:39 1544 C[0x1237], FREE: T7.
7/28 10:38:39 918 C[0x1237], FREE: recvData() error (10058)
7/28 10:38:39 69c debug: Minidump 'd:\system\Starwind\StarWind.20060728.093839.mdmp' created successfully.
