Fri Jul 07, 2006 7:46 pm
I have enabled "Allow multiple connections"
I emailed the logs you requested:
SNIPPIT----
7/5 16:00:43 fe4 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:paladin', accepted 'iqn.1991-05.com.microsoft:paladin'
7/5 16:00:43 fe4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/5 16:00:43 fe4 Params: <<< String param 'TargetName': received 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0', accepted 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0'
7/5 16:00:43 fe4 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/5 16:00:43 fe4 Params: Update OFMarkInt according to the value of OFMarker.
7/5 16:00:43 fe4 Params: Update IFMarkInt according to the value of IFMarker.
7/5 16:00:43 fe4 S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0: all of 1 allowed sessions are opened.
7/5 16:00:43 fe4 S[0x2229]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0' restrictions.
7/5 16:00:43 fe4 T[0x4]: *ERROR* Login request: device open failed.
7/5 16:00:43 fe4 C[0x1119], IN_LOGIN: recvData() error (10058)
7/5 16:00:43 fe4 C[0x1119], IN_LOGIN: *ERROR* 'recv' thread: recv failed 274a.
7/5 16:00:43 fe8 C[0x1119], IN_LOGIN: Event - LOGIN_REJECT.
7/5 16:00:43 fe8 C[0x1119], FREE: T7.
7/5 16:01:08 404 Srv: Accepted connection from 192.168.9.129:1073. id assigned - 4378
7/5 16:01:08 404 C[0x111a], FREE: Event - CONNECTED.
7/5 16:01:08 404 C[0x111a], XPT_UP: T3.
7/5 16:01:08 fb8 C[0x111a], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
7/5 16:01:08 fb8 C[0x111a], XPT_UP: Event - LOGIN.
7/5 16:01:08 fb8 C[0x111a], IN_LOGIN: T4.
7/5 16:01:08 fb8 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:paladin', accepted 'iqn.1991-05.com.microsoft:paladin'
7/5 16:01:08 fb8 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/5 16:01:08 fb8 Params: <<< String param 'TargetName': received 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0', accepted 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0'
7/5 16:01:08 fb8 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/5 16:01:08 fb8 Params: Update OFMarkInt according to the value of OFMarker.
7/5 16:01:08 fb8 Params: Update IFMarkInt according to the value of IFMarker.
7/5 16:01:08 fb8 S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0: all of 1 allowed sessions are opened.
7/5 16:01:08 fb8 S[0x222a]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0' restrictions.
7/5 16:01:08 fb8 T[0x1]: *ERROR* Login request: device open failed.
7/5 16:01:08 fb8 C[0x111a], IN_LOGIN: recvData() error (10054)
7/5 16:01:08 fb8 C[0x111a], IN_LOGIN: *ERROR* 'recv' thread: recv failed 274a.
7/5 16:01:08 bbc C[0x111a], IN_LOGIN: Event - LOGIN_REJECT.
7/5 16:01:08 bbc C[0x111a], FREE: T7.
7/5 16:01:08 404 Srv: Accepted connection from 192.168.9.129:1075. id assigned - 4379
7/5 16:01:08 404 C[0x111b], FREE: Event - CONNECTED.
7/5 16:01:08 404 C[0x111b], XPT_UP: T3.
7/5 16:01:08 ad8 C[0x111b], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
7/5 16:01:08 ad8 C[0x111b], XPT_UP: Event - LOGIN.
7/5 16:01:08 ad8 C[0x111b], IN_LOGIN: T4.
7/5 16:01:08 ad8 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:paladin', accepted 'iqn.1991-05.com.microsoft:paladin'
7/5 16:01:08 ad8 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
7/5 16:01:08 ad8 Params: <<< String param 'TargetName': received 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0', accepted 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0'
7/5 16:01:08 ad8 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
7/5 16:01:08 ad8 Params: Update OFMarkInt according to the value of OFMarker.
7/5 16:01:08 ad8 Params: Update IFMarkInt according to the value of IFMarker.
7/5 16:01:08 ad8 S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0: all of 1 allowed sessions are opened.
7/5 16:01:08 ad8 S[0x222b]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:paladin.ibv.ibv0' restrictions.
7/5 16:01:08 ad8 T[0x2]: *ERROR* Login request: device open failed.
7/5 16:01:08 ad8 C[0x111b], IN_LOGIN: recvData() error (10054)
7/5 16:01:08 ad8 C[0x111b], IN_LOGIN: *ERROR* 'recv' thread: recv failed 274a.
7/5 16:01:08 41c C[0x111b], IN_LOGIN: Event - LOGIN_REJECT.
7/5 16:01:08 41c C[0x111b], FREE: T7.
7/5 16:01:09 404 Srv: Accepted connection from 192.168.9.129:1076. id assigned - 4380
7/5 16:01:09 404 C[0x111c], FREE: Event - CONNECTED.
7/5 16:01:09 404 C[0x111c], XPT_UP: T3.
7/5 16:01:09 180 C[0x111c], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
7/5 16:01:09 180 C[0x111c], XPT_UP: Event - LOGIN.
7/5 16:01:09 180 C[0x111c], IN_LOGIN: T4.
