Migration problem - StarWind-proxmox-plugin-pve9 amd64 9.1.1.43+b73
ticktok
Sat Nov 28, 2026 2:33 am
I just installed the new StarWind plugin and went to test with a migration and this is what I got:-
2026-11-28 15:22:27 ssh tunnel ver 1
2026-11-28 15:22:28 starting migration of VM 103 to node 'pve-ruby' (192.168.182.229)
2026-11-28 15:22:28 starting VM 103 on remote node 'pve-ruby'
2026-11-28 15:22:29 [pve-ruby] live migration of VM 103 is not supported on StarLVM storage 'vgt-data': the VM's thin pool would be active on two nodes at once and could be corrupted. Shut the VM down and migrate it offline.
2026-11-28 15:22:29 ERROR: online migrate failure - remote command failed with exit code 255
2026-11-28 15:22:29 aborting phase 2 - cleanup resources
2026-11-28 15:22:29 migrate_cancel
2026-11-28 15:22:29 ERROR: migration finished with problems (duration 00:00:03)
TASK ERROR: migration problems
Is this expected??
Sat Nov 28, 2026 8:37 am
Yes, the new version of the plugin does not support live migration (see https://www.starwindsoftware.com/release-notes-starlvm). The fix that allows it should be available later, in JAN.
Stay tuned.
ticktok
Sat Nov 28, 2026 9:29 am
Opps - didn't know there was a dedicated release note section for Proxmox plugins.
I reverted to the previous plugin (version 1.1.41) and am now able to do live migrations. :D
