Proxmox & Startlvm : StarLvmPlugin" is implementing an older storage API
B38
Wed Nov 18, 2026 9:22 am
We're just setting up a new test PVE server with Starwind plugin.
PVE v9 and up to update
When we install plugin, we have this message :
Plugin "PVE::Storage::Custom::StarLvmPlugin" is implementing an older storage API, an upgrade is recommended
Same message each time we use PVESM command
Version
||/ Name                         Version      Architecture Description
ii  starwind-proxmox-plugin-pve9 1.1.41       amd64        StarWind plugin for Proxmox 9 to connect SAN-based storage and enable thin-provisioning and snapshots for VMs.
ii  pve-cluster               9.1.9        amd64        "pmxcfs" distributed cluster filesystem for Proxmox Virtual Environment.
ii  pve-container             6.1.20       all          Proxmox VE Container management tool
ii  pve-docs                  9.2.14       all          Proxmox VE Documentation
ii  pve-edk2-firmware         4.2026.08-1  all          edk2 based UEFI firmware modules for virtual machines
ii  pve-edk2-firmware-aarch64 4.2026.08-1  all          edk2 based ARM64 UEFI firmware modules for virtual machines
ii  pve-edk2-firmware-legacy  4.2026.08-1  all          edk2 based legacy 2MB UEFI firmware modules for virtual machines
ii  pve-edk2-firmware-ovmf    4.2026.08-1  all          edk2 based UEFI firmware modules for virtual machines
un  pve-edk2-firmware-riscv   <none>       <none>       (no description available)
ii  pve-esxi-import-tools     1.0.1        amd64        Tools to allow importing VMs from ESXi hosts
ii  pve-firewall              6.0.7        amd64        Proxmox VE Firewall
ii  pve-firmware              3.18-9       all          Binary firmware code for the pve-kernel
ii  pve-ha-manager            5.2.5        amd64        Proxmox VE HA Manager
ii  pve-i18n                  3.11.0       all          Internationalization support for Proxmox VE
un  pve-kernel-7.0            <none>       <none>       (no description available)
un  pve-kernel-helper         <none>       <none>       (no description available)
un  pve-kvm                   <none>       <none>       (no description available)
ii  pve-lxc-syscalld          2.0.2        amd64        PVE LXC syscall daemon
ii  pve-manager               9.2.28       all          Proxmox Virtual Environment Management Tools
ii  pve-nvidia-vgpu-helper    0.3.1        all          Proxmox Nvidia vGPU helper script and systemd service
ii  pve-qemu-kvm              11.1.3-2     amd64        Full virtualization on x86 hardware
un  pve-qemu-kvm-2.6.18       <none>       <none>       (no description available)
ii  pve-xtermjs               6.0.0-3      all          HTML/TypeScript based fully-featured terminal for Proxmox projects
ii  pve-yew-mobile-gui        0.8.0        amd64        Mobile Web UI to for the Proxmox Virtual Environment
ii  pve-yew-mobile-i18n       3.11.0       all          Internationalization support for Proxmox Virtual Environment (yew PWA)
Wed Nov 18, 2026 10:59 am
There's a new build coming.
Stay tuned.
