Failed to find logical volume vm-13649-disk-0 after reverting snapshot StarLVM plugin, FC storage
Anyone4173
Mon Jun 15, 2026 1:45 pm
We've recently migrated from ESXi to Proxmox. We are using the same storage we used at ESXI EV, it's FC SAN mounted as usual in such case.
We have two disks 15Tb each. We use Proxmox as cluster with multuple nodes, 4 nodes now active.
One is LVM - pure, no volume-chains, no other tricks, not using snapshots on it. No issues.
Another one is starlvm - for dev VMs where we need to use snapshot functionality. This is the problematic one.
For development purposes we need to use snapshots as a tool to roll-back VM changes fast and reliably.
But sometimes, randomly, during snapshot revert procedure some VMs are losing disks:
unsupported storage of vg 'star_vg_fc_san_3738'
 activating vm-13472-disk-0...
 deactivating vm-13472-disk-0...
Use of uninitialized value in string ne at /usr/share/perl5/PVE/Storage/Custom/StarLvmPlugin.pm line 481.
TASK ERROR: no such logical volume star_vg_fc_san_3738/vm-13472-disk-0
To make things consistent the snapshot reverting procedure is following:
shutdown VM (gracefully)
get list of snapshots
revert to the latest snapshot (have no parent)
start VM
I'm running this routine sequentially for each VM group(6 VMs in a group), but there are multiple VM groups at the cluster (alpha, beta, each with 6 VMs in it), and sometimes they might execute this routine for different VMs in parallel. I'm using some randomization and time shift to run snapshot and power-related tasks as random as possible. I'm not sure if this may be the cause, but it's maybe worth mentioning.
Here is the problematic VM config:
- all vms are built similarly, only name, tags, mac changes for each vm version and group
#Clone made from SOME VM
agent: enabled=1,fstrim_cloned_disks=1
boot: order=scsi0;net0
cores: 2
cpu: host
machine: q35
memory: 4096
meta: creation-qemu=11.0.0,ctime=1780414247
net0: virtio=some_MAC,bridge=somebridge,firewall=1,queues=1
onboot: 0
ostype: l26
parent: phase_2
scsi0: swsan3738lv:vm-13472-disk-0,aio=native,cache=none,detect_zeroes=1,discard=on,iothread=1,queues=2,size=70G
scsihw: virtio-scsi-single
smbios1: uuid=UUID
tags: SOME-TAGS
vmgenid: 896cef72-1765-41dd-8b93-89f4ea668e09
[phase_2]
#Cloned VM Reverting this snapshot when needed
cores: 2
cpu: host
machine: q35
memory: 4096
onboot: 0
ostype: l26
smbios1: uuid=UUID
snaptime: 1780436041
tags: SOME-TAGS
vmgenid: 1f6ec138-c221-497e-ae8f-23d69c5c92d8
I'm checking two VMs, one is already affected by this issue 13472 and another one is OK 13649.
And there are some checks I run after this fail to get the full view:
# Affected VM  13472
pvesm status
Name                  Type     Status     Total (KiB)      Used (KiB) Available (KiB)        %
local                  dir   disabled               0               0               0      N/A
local-lvm          lvmthin   disabled               0               0               0      N/A
san3739lv              lvm     active     16106123264     10011447296      6094675968   62.16%
swsan3738lv        starlvm     active     16106123264      4272119808     11834003456   26.52%
pvesm list swsan3738lv --vmid 13472
Volid Format  Type      Size VMID
sudo /usr/sbin/lvscan | grep /star_vg_fc_san_3738  | grep 13472
  inactive          '/dev/star_vg_fc_san_3738/lvmth-13472' [70.00 GiB] inherit
  inactive          '/dev/star_vg_fc_san_3738/snap_vm-13472-disk-0_phase_2' [70.00 GiB] inherit
vgs; lvs -a -o vg_name,lv_name,lv_attr,lv_size,pool_lv,data_percent,metadata_percent | grep 13472
  VG                  #PV #LV #SN Attr   VSize   VFree
  pve                   1   3   0 wz--n- 277.87g  16.00g
  star_vg_fc_san_3738   1 167   0 wz--n- <15.00t <10.96t
  vg_fc_san_3739        1  55   0 wz--n- <15.00t  <5.68t
  star_vg_fc_san_3738 lvmth-13472                    twi---tz-k   70.00g
  star_vg_fc_san_3738 [lvmth-13472_tdata]            Twi-------   70.00g
  star_vg_fc_san_3738 [lvmth-13472_tmeta]            ewi-------   72.00m
  star_vg_fc_san_3738 snap_vm-13472-disk-0_phase_2   Vri---tz-k   70.00g lvmth-13472
ls -lah /dev/star_vg_fc_san_3738/ | grep 13472
-- none ---
ls -l /dev/mapper/ | grep 13472
-- none ---
vgchange -a y star_vg_fc_san_3738
  18 logical volume(s) in volume group "star_vg_fc_san_3738" now active
lvs | grep 13472
  lvmth-13472                    star_vg_fc_san_3738 twi---tz-k   70.00g
  snap_vm-13472-disk-0_phase_2   star_vg_fc_san_3738 Vri---tz-k   70.00g lvmth-13472
# It does not help me to check the disk itself, yet
mount /dev/star_vg_fc_san_3738/lvmth-13472 /mnt/pve/
mount /dev/star_vg_fc_san_3738/snap_vm-13472-disk-0_phase_2 /mnt/pve/
# Example of healthy VM 13649
pvesm list swsan3738lv --vmid 13649
swsan3738lv:vm-13649-disk-0 raw     images    69793218560 13649
sudo /usr/sbin/lvscan | grep /star_vg_fc_san_3738  | grep 13649
  ACTIVE            '/dev/star_vg_fc_san_3738/lvmth-13649' [65.00 GiB] inherit
  inactive          '/dev/star_vg_fc_san_3738/snap_vm-13649-disk-0_phase_2' [65.00 GiB] inherit
  ACTIVE            '/dev/star_vg_fc_san_3738/vm-13649-disk-0' [65.00 GiB] inherit
vgs; lvs -a -o vg_name,lv_name,lv_attr,lv_size,pool_lv,data_percent,metadata_percent | grep 13649
  star_vg_fc_san_3738 lvmth-13649                    twi-aotz-k   65.00g             30.48  20.12
  star_vg_fc_san_3738 [lvmth-13649_tdata]            Twi-ao----   65.00g
  star_vg_fc_san_3738 [lvmth-13649_tmeta]            ewi-ao----   68.00m
  star_vg_fc_san_3738 snap_vm-13649-disk-0_phase_2   Vri---tz-k   65.00g lvmth-13649
  star_vg_fc_san_3738 vm-13649-disk-0                Vwi-aotz-k   65.00g lvmth-13649 28.84
ls -l /dev/mapper/ | grep 13649
lrwxrwxrwx 1 root root       8 Jun 12 08:34 star_vg_fc_san_3738-lvmth--13649 -> ../dm-45
The interesting part is in the working VM:
So, if I understand correctly, using example of unaffected VM:
1 VM main disk as volume lvmth-13649 twi-aotz-k 65.00g
2 VM disk mounted volume as disk vm-13649-disk-0 Vwi-aotz-k 65.00g lvmth-13649
3 VM snapshot separate volume, mounted as disk? snap_vm-13649-disk-0_phase_2 Vri---tz-k 65.00g lvmth-13649
Affected VM somehow lost the mount #2 during the procudure of snapshot reverting:
1 VM main disk as volume lvmth-13472 twi---tz-k 70.00g
2 VM disk mounted LOST? no such logical volume star_vg_fc_san_3738/vm-13472-disk-0
3 VM snapshot separate volume, mounted as disk? snap_vm-13472-disk-0_phase_2 Vri---tz-k 70.00g lvmth-13472
Questions:
What am I doing wrong?
Is there a way to mount lost volume again, since I still have a snapshot and original disk of affected VM in place?
UPD: I'm still investigating the issue, trying to find a cause and to blame some network issues or improper setup, or concurrency, but I cannot find a strong evidence or a proper error in host logs.
It happens randomly and I cannot recreate the issue running snapshot reverting routine in loop for 100 times in parallel to normal routines. I tried switching this routine in thread-running case or in sequential execution: one vm after another - and it still happens.
UPD2: Trying to revert snapshot for affected VM throw error:
This is new vm, new ID, but the same issue.​
TASK ERROR: lvremove 'star_vg_fc_san_3738/vm-19582-disk-0' error:   Failed to find logical volume "star_vg_fc_san_3738/vm-19582-disk-0"
This is something I'm trying to find workaround for too: how can I skip this error or make a dummy mount to fool Proxmox into thinking it actually "deleted" an old disk-0 and replaced it with snapshot version of VM disk?
UPD3: Just for fun I've created a fake volume to trick Proxmox into thinking it can delete this fake volume and assign snapshot disk back. But it does not work:
qm unlock 19582
lvcreate -L 1M -n vm-19582-disk-0 star_vg_fc_san_3738
sudo /usr/sbin/lvscan | grep vm-19582-disk-0
  inactive          '/dev/star_vg_fc_san_3738/snap_vm-19582-disk-0_phase_2' [65.00 GiB] inherit
  ACTIVE            '/dev/star_vg_fc_san_3738/vm-19582-disk-0' [4.00 MiB] inherit
Snapshot revert task returned:
  Consider pruning star_vg_fc_san_3738 VG archive with more than 992 MiB in 7774 files (see archiving settings in lvm.conf).
  Logical volume "vm-19582-disk-0" successfully removed.
  Thin pool star_vg_fc_san_3738-lvmth--19582-tpool (252:90) transaction_id is 10, while expected 9.
TASK ERROR: lvm rollback 'star_vg_fc_san_3738/snap_vm-19582-disk-0_phase_2' error:   Aborting. Failed to locally activate thin pool star_vg_fc_san_3738/lvmth-19582.
Checking:
lvconvert --repair star_vg_fc_san_3738/lvmth-19582
  Consider pruning star_vg_fc_san_3738 VG archive with more than 992 MiB in 7779 files (see archiving settings in lvm.conf).
  Consider pruning star_vg_fc_san_3738 VG archive with more than 992 MiB in 7780 files (see archiving settings in lvm.conf).
  WARNING: LV star_vg_fc_san_3738/lvmth-19582_meta0 holds a backup of the unrepaired metadata. Use lvremove when no longer required.
Thanks in advance
Tue Jun 16, 2026 8:41 am
Welcome to StarWind Forum! It looks like the StarLVM needs updating. Could you please try https://knowledgebase.starwindsoftware. ... 9-upgrade/
Anyone4173
Tue Jun 16, 2026 2:08 pm
I've just finished the install/update routine yesterday, for all nodes in cluster and restarted each node:
Installation completed: 2026-05-25 15:13:42
Repository used: http://repo.starwind.com/proxmox/
Signed repository: true
Installation started: 2026-06-15 14:22:20
[INFO] 2026-06-15 14:22:20 - Starting StarWind Proxmox VE 9 plugin installation
[INFO] 2026-06-15 14:22:20 - ================================================
[INFO] 2026-06-15 14:22:20 - Old package(s) to remove: starwind-proxmox-plugin
[INFO] 2026-06-15 14:22:20 - New package(s) to install: starwind-proxmox-plugin-pve9
[INFO] 2026-06-15 14:22:20 - Log file: /var/log/starwind/starwind-proxmox-plugin/install.log
[INFO] 2026-06-15 14:22:20 - Backup directory: /root/old-apt-configs/backup
[INFO] 2026-06-15 14:22:22 - Detected Proxmox VE version: 9
[INFO] 2026-06-15 14:22:22 - Selecting appropriate repository...
[INFO] 2026-06-15 14:22:22 - Testing public repository: http://repo.starwind.com/proxmox/
[INFO] 2026-06-15 14:22:22 - Public repository URL is accessible
[INFO] 2026-06-15 14:22:22 - Testing repository configuration: http://repo.starwind.com/proxmox/
[TEST] 2026-06-15 14:22:22 - Testing repository: http://repo.starwind.com/proxmox/
Hit:1 https://repo.starwind.com/proxmox trixie InRelease
Reading package lists...
[INFO] 2026-06-15 14:22:22 - Repository test successful
[INFO] 2026-06-15 14:22:22 - Selected: PUBLIC SIGNED REPOSITORY
[INFO] 2026-06-15 14:22:22 - Cleaning up old repository configurations...
[INFO] 2026-06-15 14:22:22 - Backed up legacy GPG key to: /root/old-apt-configs/backup/starwind-proxmox.gpg.backup.20260615_142222
[INFO] 2026-06-15 14:22:22 - Removed legacy GPG key
[INFO] 2026-06-15 14:22:22 - Checking for old plugin installation (PVE 8 version)...
[INFO] 2026-06-15 14:22:22 - No old plugin installation found
[INFO] 2026-06-15 14:22:22 - GPG key already installed from testing phase
[INFO] 2026-06-15 14:22:22 - Configuring Proxmox VE 9 (trixie) repository...
[INFO] 2026-06-15 14:22:22 - Backed up existing sources file to: /root/old-apt-configs/backup/starwind-proxmox.sources.backup.20260615_142222
[INFO] 2026-06-15 14:22:22 - Configuring signed repository with GPG verification
[INFO] 2026-06-15 14:22:22 - Repository configuration written successfully to: /etc/apt/sources.list.d/starwind-proxmox.sources
[CONFIG] 2026-06-15 14:22:22 - Repository configuration:
Types: deb
URIs: http://repo.starwind.com/proxmox/
Suites: trixie
Components: main
Signed-By: /usr/share/keyrings/starwind-proxmox.gpg
[INFO] 2026-06-15 14:22:22 - Updating APT metadata...
[CMD] 2026-06-15 14:22:22 - Running: apt update
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://download.proxmox.com/debian/ceph-squid trixie InRelease
Hit:3 http://deb.debian.org/debian trixie-updates InRelease
Hit:4 http://security.debian.org/debian-security trixie-security InRelease
Hit:6 http://download.proxmox.com/debian/pve trixie InRelease
Hit:5 https://repo.starwind.com/proxmox trixie InRelease
Building dependency tree...
Reading state information...
All packages are up to date.
[INFO] 2026-06-15 14:22:24 - APT metadata updated successfully
[INFO] 2026-06-15 14:22:24 - StarWind repository is accessible and working
[INFO] 2026-06-15 14:22:24 - Installing/upgrading StarWind packages for PVE 9...
[INFO] 2026-06-15 14:22:24 - Package to install: starwind-proxmox-plugin-pve9
[INFO] 2026-06-15 14:22:24 - Running apt install
[CMD] 2026-06-15 14:22:24 - Running: apt install -y starwind-proxmox-plugin-pve9
starwind-proxmox-plugin-pve9 is already the newest version (1.1.38).
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
[INFO] 2026-06-15 14:22:25 - Packages installed successfully
[INFO] 2026-06-15 14:22:25 - Verifying installation...
[INFO] 2026-06-15 14:22:25 - Checking old packages are removed...
[INFO] 2026-06-15 14:22:25 - Old package starwind-proxmox-plugin is removed
[INFO] 2026-06-15 14:22:25 - Checking new packages are installed...
[INFO] 2026-06-15 14:22:25 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
[INFO] 2026-06-15 14:22:25 - ================================================
[INFO] 2026-06-15 14:22:25 - StarWind plugin successfully updated for Proxmox VE 9
[INFO] 2026-06-15 14:22:25 - Repository used: http://repo.starwind.com/proxmox/
[INFO] 2026-06-15 14:22:25 - Signed: true
[INFO] 2026-06-15 14:22:25 - Full installation log available at: /var/log/starwind/starwind-proxmox-plugin/install.log
Installation completed: 2026-06-15 14:22:25
Moreover, back in May I've tested it too, to be sure it was installed properly:
[CMD] 2026-05-25 15:13:41 - Running: apt install -y starwind-proxmox-plugin-pve9
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 110
[INFO] 2026-05-25 15:13:42 - Packages installed successfully
So the issue with snapshots was there since May even with the latest/newest version of the plugin.
Tue Jun 16, 2026 6:39 pm
Thanks for your update. Will log an internal ticket with my colleagues.
Tue Jun 16, 2026 6:59 pm
Could you please collect the plugin logs?
/opt/starwind/starwind-proxmox-plugin/collect_pve_logs.sh
If you have multiple nodes, run it for every node.
Share it with me https://www.starwindsoftware.com/support-form (use existing ticket 1508639)
Please also include the time stamps for an incident.
Anyone4173
Wed Jun 17, 2026 7:21 am
Double-checked for all nodes:
[INFO] 2026-05-25 15:36:12 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
[INFO] 2026-06-15 14:22:26 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
PROXMOXNODE-cl2-1:~# uptime
 15:10:31 up 1 day, 1 min,  2 users,  load average: 0.55, 0.54, 0.48
[INFO] 2026-05-25 15:36:13 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
PROXMOXNODE-cl2-2:~# uptime
 15:10:31 up 1 day, 1 min,  2 users,  load average: 0.13, 0.05, 0.01
PROXMOXNODE-cl2-3:~# uptime
 15:10:31 up 1 day, 1 min,  2 users,  load average: 0.12, 0.09, 0.05
PROXMOXNODE-cl2-4:~# uptime
 15:10:31 up 1 day, 2 min,  2 users,  load average: 0.58, 0.62, 0.55
[INFO] 2026-05-25 15:13:42 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
PROXMOXNODE-cl2-5:~# uptime
 15:10:31 up 1 day, 37 min,  2 users,  load average: 15.95, 18.33, 16.13
[INFO] 2026-05-25 15:13:41 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
[INFO] 2026-06-15 14:22:24 - starwind-proxmox-plugin-pve9 is installed (version: 1.1.38)
PROXMOXNODE-cl2-6:~# uptime
 15:10:31 up 1 day, 5 min, 14 users,  load average: 1.97, 3.97, 3.34
PROXMOXNODE-cl2-7:~# uptime
 15:10:31 up 23:54,  2 users,  load average: 0.52, 0.61, 0.64
PROXMOXNODE-cl2-8:~# uptime
 15:10:31 up 23:54,  2 users,  load average: 0.59, 0.91, 0.96
BTW: This is not helping: " Forbidden. You sent forms too often. Please wait a few minutes. Massive posting. Anti-Spam by CleanTalk. "
Wed Jun 17, 2026 8:25 am
Yeah, that log is not a massive help.
Can you also pull a pvereport bundle for me? Please indicate the time stamps for the incident.
pvereport > /tmp/pve_support_report.txt
p.s.
This DOES help us to prevent mass spam attacks. I have to approve "real person" comments less often than I want.
Mon Jul 13, 2026 1:20 pm
Thanks for your patience. The new version of the plugin is there. Give it a try.
