/Damir
2/25 22:43:20 c74 Srv: StarWind iSCSI Target v3.0 (Build 20060306, Win32)
2/25 22:43:20 c74 Srv: *** TRIAL VERSION *** [ expires in 15 day(s) ]
2/25 22:43:20 c74 Srv: Please contact Rocket Division Software at <info@rocketdivision.com> for more details.
2/25 22:43:20 c74 Srv: Unlimited number of client hosts allowed.
2/25 22:43:20 c74 Srv: Config file: 'StarWind.cfg'
2/25 22:43:20 c74 conf: 'LogLevel' = '1'
2/25 22:43:20 c74 conf: 'LogMask' = '0x8fffffff'
2/25 22:43:20 c74 conf: 'Port' = '3260'
2/25 22:43:20 c74 conf: 'Interface' = '0.0.0.0'
2/25 22:43:20 c74 conf: 'Login' = 'root'
2/25 22:43:20 c74 conf: 'Password' = '##tgHFBST0pBKGY5NL4ydJrg=='
2/25 22:43:20 c74 conf: 'Echo' = 'no'
2/25 22:43:20 c74 conf: 'MinBufferSize' = '65536'
2/25 22:43:20 c74 conf: 'AlignmentMask' = '0x0000'
2/25 22:43:20 c74 conf: 'MaxPendingRequests' = '64'
2/25 22:43:20 c74 conf: 'DefTargetName' = 'EndlessGaming:DF.$(symid)'
2/25 22:43:20 c74 conf: read command: addplugin -module:"RamDisk.dll" -symlink:"RamDrive" -type:"RAM disk"
2/25 22:43:20 c74 conf: read command: addplugin -module:"ImageFile.dll" -symlink:"ImageFile" -type:"Image file" -imagedir:"*|cmdfv|My Computer|img" -imagedir:"*|cv|IBVolume images|ibv" -volumes:"no"
2/25 22:43:20 c74 conf: read command: addplugin -module:"VirtualDvd.dll" -symlink:"VirtualDvd" -type:"Virtual DVD" -imagedir:"*|mv|My Computer|mds,iso"
2/25 22:43:20 c74 conf: read command: addplugin -module:"IBVolume.dll" -symlink:"IBV" -type:"IBV" -imagedir:"*|cdmfv|My Computer|ibv" -imagedir:"*|cdmfv|Snapshots|ibvss" -imagedir:"*|cv|Image Files|img,dat"
2/25 22:43:20 c74 conf: read command: add "IBV0" -file:"My Computer\J\IBV\ibv0.ibv" -mode:"3" -clustered:"no" -asyncmode:"yes"
2/25 22:43:20 c74 conf: read command: add "IBV1" -file:"My Computer\J\IBV\ibv1.ibv" -mode:"3" -clustered:"no" -asyncmode:"yes"
22/25 22:43:21 c74 conf: read command: add "IBV49" -file:"My Computer\J\IBV\ibv49.ibv" -mode:"3" -clustered:"no" -asyncmode:"yes"
2/25 22:43:21 c74 conf: read command: add "IBV50" -file:"My Computer\J\IBV\ibv50.ibv" -mode:"3" -clustered:"no" -asyncmode:"yes"
2/25 22:43:21 c74 conf: Variable 'LogLevel' is set to '1'.
2/25 22:43:21 c74 conf: Variable 'LogMask' is set to '0x8fffffff'.
2/25 22:43:21 c74 conf: Variable 'Port' is set to '3260'.
2/25 22:43:21 c74 conf: Variable 'Interface' is set to '0.0.0.0'.
2/25 22:43:21 c74 conf: Variable 'Login' is set to 'root'.
2/25 22:43:21 c74 conf: Variable 'Password' is set to '##tgHFBST0pBKGY5NL4ydJrg=='.
2/25 22:43:21 c74 conf: Variable 'Echo' is set to 'no'.
2/25 22:43:21 c74 conf: Variable 'MinBufferSize' is set to '65536'.
2/25 22:43:21 c74 conf: Variable 'AlignmentMask' is set to '0x0000'.
2/25 22:43:21 c74 conf: Variable 'MaxPendingRequests' is set to '64'.
2/25 22:43:21 c74 conf: Variable 'DefTargetName' is set to 'EndlessGaming:DF.$(symid)'.
2/25 22:43:21 c74 conf: 'RamDisk.dll' loaded successfully.
2/25 22:43:21 c74 Plugin: Calling m_SscPort_InitEx
2/25 22:43:21 c74 IMAGE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img'
Dirname: '*'
Rights: 0x9
Alias: 'IBVolume images'
Extensions: 'ibv'
2/25 22:43:21 c74 conf: 'ImageFile.dll' loaded successfully.
2/25 22:43:21 c74 VDVD: *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
2/25 22:43:21 c74 conf: 'VirtualDvd.dll' loaded successfully.
2/25 22:43:21 c74 IBV: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x1f
Alias: 'Snapshots'
Extensions: 'ibvss'
Dirname: '*'
Rights: 0x9
Alias: 'Image Files'
Extensions: 'img,dat'
2/25 22:43:21 c74 conf: 'IBVolume.dll' loaded successfully.
2/25 22:43:21 c74 S: the device 'IBV0' is opened successfully.
2/25 22:43:21 c74 S: Assigned target name: 'endlessgaming:df.ibv.ibv0', SymId: 'IBV.IBV0'.
2/25 22:43:21 c74 S: parameter 'file', value 'My Computer\J\IBV\ibv0.ibv'.
2/25 22:43:21 c74 S: parameter 'mode', value '3'.
2/25 22:43:21 c74 S: parameter 'JournalSwitchPeriod', value '0'.
2/25 22:43:21 c74 S: parameter 'MaxStoredSessions', value '0'.
2/25 22:43:21 c74 S: parameter 'asyncmode', value 'yes'.
2/25 22:43:21 c74 S: parameter 'ImageSizeLow', value '0'.
2/25 22:43:21 c74 S: parameter 'ImageSizeHigh', value '75'.
2/25 22:43:21 c74 S: parameter 'CurrentMode', value '3'.
2/25 22:43:21 c74 S: parameter 'LastSessionId', value '1'.
2/25 22:43:21 c74 S: parameter 'BaseImageFile', value 'I:\Master.img'.
2/25 22:43:21 c74 S: endlessgaming:df.ibv.ibv0: 1 session(s) allowed.
2/25 22:43:21 c74 conf: Target [0xc5d18] has been created. Device 'IBV0' is accesible as target 'endlessgaming:df.ibv.ibv0'.
2/25 22:43:22 c74 S: the device 'IBV1' is opened successfully.
2/25 22:43:22 c74 S: Assigned target name: 'endlessgaming:df.ibv.ibv1', SymId: 'IBV.IBV1'.
2/25 22:43:22 c74 S: parameter 'file', value 'My Computer\J\IBV\ibv1.ibv'.
2/25 22:43:22 c74 S: parameter 'mode', value '3'.
2/25 22:43:22 c74 S: parameter 'JournalSwitchPeriod', value '0'.
2/25 22:43:22 c74 S: parameter 'MaxStoredSessions', value '0'.
2/25 22:43:22 c74 S: parameter 'asyncmode', value 'yes'.
2/25 22:43:22 c74 S: parameter 'ImageSizeLow', value '0'.
2/25 22:43:22 c74 S: parameter 'ImageSizeHigh', value '75'.
2/25 22:43:22 c74 S: parameter 'CurrentMode', value '3'.
2/25 22:43:22 c74 S: parameter 'LastSessionId', value '1'.
2/25 22:43:22 c74 S: parameter 'BaseImageFile', value 'I:\Master.img'.
2/25 22:43:22 c74 S: endlessgaming:df.ibv.ibv1: 1 session(s) allowed.
2/25 22:43:22 c74 conf: Target [0xc8828] has been created. Device 'IBV1' is accesible as target 'endlessgaming:df.ibv.ibv1'.
2/25 22:43:28 c74 S: the device 'IBV46' is opened successfully.
2/25 22:43:28 c74 S: Assigned target name: 'endlessgaming:df.ibv.ibv46', SymId: 'IBV.IBV46'.
2/25 22:43:28 c74 S: parameter 'file', value 'My Computer\J\IBV\ibv46.ibv'.
2/25 22:43:28 c74 S: parameter 'mode', value '3'.
2/25 22:43:28 c74 S: parameter 'JournalSwitchPeriod', value '0'.
2/25 22:43:28 c74 S: parameter 'MaxStoredSessions', value '0'.
2/25 22:43:28 c74 S: parameter 'asyncmode', value 'yes'.
2/25 22:43:28 c74 S: parameter 'ImageSizeLow', value '0'.
2/25 22:43:28 c74 S: parameter 'ImageSizeHigh', value '75'.
2/25 22:43:28 c74 S: parameter 'CurrentMode', value '3'.
2/25 22:43:28 c74 S: parameter 'LastSessionId', value '1'.
2/25 22:43:28 c74 S: parameter 'BaseImageFile', value 'I:\Master.img'.
2/25 22:43:28 c74 S: endlessgaming:df.ibv.ibv46: 1 session(s) allowed.
2/25 22:43:28 c74 conf: Target [0xe6d70] has been created. Device 'IBV46' is accesible as target 'endlessgaming:df.ibv.ibv46'.
2/25 22:43:28 c74 IBV: *ERROR* IBVolume_CreateInternal: 'J:\Journals\ibv47_00000001.ibvm': MapViewOfFile (err:
2/25 22:43:28 c74 IBV: *ERROR* SscPort_Create: Create('My Computer\J\IBV\ibv47.ibv') error (0xc0000001)!
2/25 22:43:28 c74 SCSI: Failed to create 'IBV47' device.
2/25 22:43:28 c74 S: *ERROR* cannot open the device 'IBV47'.
2/25 22:43:28 c74 Srv: * Device test failed for 'IBV47'.
2/25 22:43:28 c74 conf: Device test failed for 'IBV47'.
2/25 22:43:28 c74 IBV: *ERROR* IBVolume_CreateInternal: 'J:\Journals\ibv48_00000001.ibvm': MapViewOfFile (err:
2/25 22:43:28 c74 IBV: *ERROR* SscPort_Create: Create('My Computer\J\IBV\ibv48.ibv') error (0xc0000001)!
2/25 22:43:28 c74 SCSI: Failed to create 'IBV48' device.
2/25 22:43:28 c74 S: *ERROR* cannot open the device 'IBV48'.
2/25 22:43:28 c74 Srv: * Device test failed for 'IBV48'.
2/25 22:43:28 c74 conf: Device test failed for 'IBV48'.
2/25 22:43:28 c74 IBV: *ERROR* IBVolume_CreateInternal: 'J:\Journals\ibv49_00000001.ibvm': MapViewOfFile (err:
2/25 22:43:28 c74 IBV: *ERROR* SscPort_Create: Create('My Computer\J\IBV\ibv49.ibv') error (0xc0000001)!
2/25 22:43:28 c74 SCSI: Failed to create 'IBV49' device.
2/25 22:43:28 c74 S: *ERROR* cannot open the device 'IBV49'.
2/25 22:43:28 c74 Srv: * Device test failed for 'IBV49'.
2/25 22:43:28 c74 conf: Device test failed for 'IBV49'.
2/25 22:43:28 c74 IBV: *ERROR* IBVolume_CreateInternal: 'J:\Journals\ibv50_00000001.ibvm': MapViewOfFile (err:
2/25 22:43:28 c74 IBV: *ERROR* SscPort_Create: Create('My Computer\J\IBV\ibv50.ibv') error (0xc0000001)!
2/25 22:43:28 c74 SCSI: Failed to create 'IBV50' device.
2/25 22:43:28 c74 S: *ERROR* cannot open the device 'IBV50'.
2/25 22:43:28 c74 Srv: * Device test failed for 'IBV50'.
2/25 22:43:28 c74 conf: Device test failed for 'IBV50'.
2/25 22:43:28 c74 Srv: Refreshing device list (plugins)...
2/25 22:43:28 c74 Srv: Binding to 0.0.0.0:3260 ...
2/25 22:43:28 c74 Srv: Waiting for a connection at port 0.0.0.0:3260 ...
2/25 22:43:28 d54 conf: Waiting for a control connection at port 3261 ...
2/25 22:43:46 c74 Srv: Accepted connection from 10.10.4.118:1047. id assigned - 4370
2/25 22:43:46 c74 C[0x1112], FREE: Event - CONNECTED.
2/25 22:43:46 c74 C[0x1112], XPT_UP: T3.
2/25 22:43:46 d04 C[0x1112], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
2/25 22:43:46 d04 C[0x1112], XPT_UP: Event - LOGIN.
2/25 22:43:46 d04 C[0x1112], IN_LOGIN: T4.
2/25 22:43:46 d04 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:3d236b9c23ad4d6', accepted 'iqn.1991-05.com.microsoft:3d236b9c23ad4d6'
2/25 22:43:46 d04 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
2/25 22:43:46 d04 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
2/25 22:43:46 d04 Params: Update OFMarkInt according to the value of OFMarker.
2/25 22:43:46 d04 Params: Update IFMarkInt according to the value of IFMarker.
2/25 22:43:46 d04 T[0x1]: Anonymous connection allowed.
2/25 22:43:46 d04 Params: >>> AuthMethod=None.
2/25 22:43:46 25c T[0x1]: The end of stage 0, next stage is 1.
2/25 22:43:46 d04 Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
2/25 22:43:46 d04 Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
2/25 22:43:46 d04 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
2/25 22:43:46 d04 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
2/25 22:43:46 d04 Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
2/25 22:43:46 d04 Params: >>> HeaderDigest=None.
2/25 22:43:46 d04 Params: >>> DataDigest=None.
2/25 22:43:46 d04 Params: >>> InitialR2T=No.
2/25 22:43:46 d04 Params: >>> ImmediateData=Yes.
2/25 22:43:46 d04 Params: >>> MaxRecvDataSegmentLength=65536.
2/25 22:43:46 d04 Params: >>> MaxBurstLength=262144.
2/25 22:43:46 d04 Params: >>> FirstBurstLength=65536.
2/25 22:43:46 d04 Params: >>> DefaultTime2Wait=2.
2/25 22:43:46 d04 Params: >>> DefaultTime2Retain=20.
2/25 22:43:46 d04 Params: >>> MaxOutstandingR2T=1.
2/25 22:43:46 d04 Params: >>> DataPDUInOrder=Yes.
2/25 22:43:46 d04 Params: >>> DataSequenceInOrder=Yes.
2/25 22:43:46 25c T[0x1]: The end of stage 1, next stage is 3.
2/25 22:43:46 25c C[0x1112], IN_LOGIN: Event - LOGIN_ACCEPT.
2/25 22:43:46 25c C[0x1112], LOGGED_IN: T5.
2/25 22:43:46 25c C[0x1112], LOGGED_IN: Event - LOGOUT.
2/25 22:43:46 25c C[0x1112], IN_LOGOUT: T9/10.
2/25 22:43:46 cc4 C[0x1112], IN_LOGOUT: Event - LOGOUT_ACCEPT.
2/25 22:43:46 cc4 C[0x1112], FREE: T13.
2/25 22:43:49 c74 Srv: Accepted connection from 10.10.4.118:1048. id assigned - 4371
2/25 22:43:49 c74 C[0x1113], FREE: Event - CONNECTED.
2/25 22:43:49 c74 C[0x1113], XPT_UP: T3.
2/25 22:43:49 d6c C[0x1113], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
2/25 22:43:49 d6c C[0x1113], XPT_UP: Event - LOGIN.
2/25 22:43:49 d6c C[0x1113], IN_LOGIN: T4.
2/25 22:43:49 d6c Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:3d236b9c23ad4d6', accepted 'iqn.1991-05.com.microsoft:3d236b9c23ad4d6'
2/25 22:43:49 d6c Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
2/25 22:43:49 d6c Params: <<< String param 'TargetName': received 'endlessgaming:df.ibv.ibv11', accepted 'endlessgaming:df.ibv.ibv11'
2/25 22:43:49 d6c Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
2/25 22:43:49 d6c Params: Update OFMarkInt according to the value of OFMarker.
2/25 22:43:49 d6c Params: Update IFMarkInt according to the value of IFMarker.
2/25 22:43:49 d6c S: endlessgaming:df.ibv.ibv11: 1 session(s) are opened, 0 more allowed.
2/25 22:43:49 d6c T[0x1]: Anonymous connection allowed.
2/25 22:43:49 d6c Params: >>> AuthMethod=None.
2/25 22:43:49 d6c Params: >>> TargetPortalGroupTag=1.
2/25 22:43:49 d74 T[0x1]: The end of stage 0, next stage is 1.
2/25 22:43:49 d6c Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
2/25 22:43:49 d6c Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
2/25 22:43:49 d6c Params: <<< Numeric param 'ErrorRecoveryLevel': received 2, accepted 0
2/25 22:43:49 d6c Params: <<< Boolean param 'InitialR2T': received No, accepted 0
2/25 22:43:49 d6c Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
2/25 22:43:49 d6c Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
2/25 22:43:49 d6c Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
2/25 22:43:49 d6c Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
2/25 22:43:49 d6c Params: <<< Numeric param 'MaxConnections': received 4, accepted 1
2/25 22:43:49 d6c Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
2/25 22:43:49 d6c Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
2/25 22:43:49 d6c Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
2/25 22:43:49 d6c Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
2/25 22:43:49 d6c Params: <<< Numeric param 'MaxOutstandingR2T': received 16, accepted 1
2/25 22:43:49 d6c Params: >>> ErrorRecoveryLevel=0.
2/25 22:43:49 d6c Params: >>> MaxConnections=1.
2/25 22:43:49 d6c Params: >>> HeaderDigest=None.
2/25 22:43:49 d6c Params: >>> DataDigest=None.
2/25 22:43:49 d6c Params: >>> InitialR2T=No.
2/25 22:43:49 d6c Params: >>> ImmediateData=Yes.
2/25 22:43:49 d6c Params: >>> MaxRecvDataSegmentLength=262144.
2/25 22:43:49 d6c Params: >>> MaxBurstLength=262144.
2/25 22:43:49 d6c Params: >>> FirstBurstLength=65536.
2/25 22:43:49 d6c Params: >>> DefaultTime2Wait=2.
2/25 22:43:49 d6c Params: >>> DefaultTime2Retain=20.
2/25 22:43:49 d6c Params: >>> MaxOutstandingR2T=1.
2/25 22:43:49 d6c Params: >>> DataPDUInOrder=Yes.
2/25 22:43:49 d6c Params: >>> DataSequenceInOrder=Yes.
2/25 22:43:49 d74 T[0x1]: The end of stage 1, next stage is 3.
2/25 22:43:49 d74 C[0x1113], IN_LOGIN: Event - LOGIN_ACCEPT.
2/25 22:43:49 d74 C[0x1113], LOGGED_IN: T5.
2/25 23:50:19 b4c IBV: *ERROR* IBVolume_IoThread: IoReq 1DB3B1E8 WriteFileEx(000003B4) failed (err: 112)!
2/25 23:50:19 b4c IBV: *ERROR* IBVolume_IoCompleted: IoReq 1DB3B1E8, file 000003B4 Error (112), len 0 returned!
2/25 23:50:19 b4c IBV: *ERROR* IBVolume_IoCompleted: IoReq 1DB3B008, file 000003B4 Error (112), len 0 returned!
